Bad Tranny?...
Bad Tranny?...
Ok, i was driving yesterday in my 2k2 Automatic Civic Sedan (on 20's with a gold line drop in case that is the problem) and my car acted like it was in neutral when i was still in drive. I happened to roll to some upholstry place and parked my car to check it out.(barely made it) I put it in every gear including reverse and it still was acting like it was in neutral and just revving up my engine. Then, i noticed that the engine light turned on. I have no idea what the problem is but i'm pretty sure that it is the tranny cause i still have transmission oil in the engine. I checked everything else that it could be and everything is fine. If you know alot about honda tranny's or anything about what my problem is, please help!!!! my car is still parked in some parking lot and it might get towed!!
tranny is dead for sure. it can't grab the gears anymore. classic sign of slippage that went too far. You need a new trans. Have it towed to a reputable transmission shop to get checked out. don't take it to dealer unless you have warranty cause its very expensive. $2-3K
Gearbox, if that were the case wouldn't there be some sort of grinding, or some negative noise comming from it to alert you. If that were the case I think he would have included that in his question.
Gear is right you'll get raped if you take it to honda without a warrenty.
Crayons taste like purple...
Originally Posted by gearbox
nope on the auto tranny, it slips and eventually the rpms just rev like its in neutral and the car won't move.
any signs this is happening or about to happen?
mine doesn't do it but I don't want to be in the same boat....
anyone know if this will happen even if you keep up maintenace on the tranny? (flushes and fills and full drains)
yeah the auto tranny in the 7thgen is weird it doesn't have belts but actually clutches, the teeth have been ground off so it can't catch anymore.
signs-normally when the car shifts the rpms will jump up anywhere from 100-1000 rpms possibly more , it's because it can't catch so it revs high until it does catch. you can sometimes get lucky and the tranny will last 10,000 miles more or only 10 miles more, mine has been slipping for about 3000 miles but that was because I was boosting too high and now I'm going to pick up a new one this weekend..
not necessarily. a few people here drive normal and theirs still went out before 100k. the key is try and change fluid every 10k, and also our tranny REQUIRES some sort of oil cooler.
what this oil cooler isn't something that is already installed?
( i get my fluid changed every 25-30k gonna do the second one here in a lil I'm @58k)
some of you are forgetting that a check engine light is on here. SO a failed tranny shouldnt be assumed untill the diagnosis of the check engine light is complete.
well first find out what trouble code your engine is throwing. If it wont shift into any gear and you have a check engine light, 9 times out of 10 the problem is related to that check engine light. As I tell everyone, one problem can be the cause of 20 other problems. Everything on the car works together so when one sensor or actuator is messed up or out of specs, once the ECU recieves that reading and based on that reading will be what other sensors and actuators recieve. And if the signal is messed up, well those other sensors will recieve messed up signals. The same goes with the tranny. I dont have alot of experience with auto trannies, but there are several codes associated with the trans. And alot of the electronics in the tranny go through the PCM because it contains the transmission control module.
So find out what the code is first and let me know. I can look up in my manaul and help you troubleshoot it and possibly fix the problem. But worst case senerio, you may have a failed tranny. But dont assume that yet untill the check engine light is diagnosed.
And make sure next time to only post vehicle issue problems in the vehicle issues problem forums. you had one in there which I deleted since that one had no replies and this one did. This one will probably get moved to that forum anyway.
my tranny is fine ...I'm feelin for the thread starter...tough times in a civ...I'm glad all my tranny does is clunk into reverse when I'm on an incline...
oops i missed the cel part. but it could also be one of the many cel codes for the tranny. get a cooler. they come stock on the hx auto but not on the others for some reason.
okay i know that ( I have service manual). But if you look at the hx cvt auto it has an actual "separate" cooler much like aftermarket brands that is alot smaller than the radiator. Thats what I meant, sorry if it wasn't clear.
well guys, thanks for the input but i think that most likely that it is the transmission. I might go with a manual swap, who knows. I asked one of my friends and they said that the problem could be my 20's because if i push my car too hard, it will affect the transmission. If that is the case, I have some 20" Lexani Slate Chrome Rims w/ Nitto 555 tires with about 70% tread life in them (225/35/20). They are 4x100 lug pattern with all center caps. hehe, just in case that was the problem because i want to get a full type-b lip kit, a set of ground control coilovers, jdm sedan taillights, and 18" Rev V Model II wheels and slam it 3.5 inches. Maybe a carbon fiber hood with black housing headlights. What a transformation hehe. Well let me know if you guys find anything else.
Before you start waisiting money on a new tranny, find out the code. You may be suprised that this problem is related to a simple and inexpensive part that failed.
If you are doing a manual swap. Let me know I have one sitting in my garage. It is left over from my K24 swap.
cgavin1
Jul 7, 2015 07:10 AM
robbie374
Jul 7, 2015 02:56 AM
