VIN # help please!!!
I am trying to do a carfax search on a car to find info on it and i am needing some help from you people.
This is for 01-05 coupe people i guess(mainly 2001 ex coupes)
My VIN reads as follows
1HGEM2***********
I am needing to find out if your coupe has those first 6 digits the same such as "1HGEM2".
I'm having trouble and think i got a wrong VIN from the company and they cant pull the VIN so i basically need to see if all the 01 ex coupes have those first 6 digits/letters.
The VIN they gave me is...
1HG1W12M259305063 : and i have entered everything possible around that and its not the correct VIN.
Thanks,
Injen
1HGEM2***********
Thanks,
Injen
^ well then what the hell does the vin go to on the one above? 02-05 maybe?
I am trying to get a tranny from that certain car which is supposed to be an 01 civic, do the 02-05 trannys work in an 01?
Injen
Injen
Injen
Injen
You should be good to go. Thread Starter
here is the original VIN # they gave me which has to many digits.
1HG1WW12M259305063
I would think its got to be some type of civic since the VIN starts out the same as mine( 1HG ), but the rest doesnt match up.
I have tried entering a "E" in place of the 2 to make it "WW1EM2" and tried replacing the 5's with S's single and double. I dont know, but they do have a 30 day garuantee on the tranny no matter what happens, whether it wont fit or wont work for $650.00 and thats the cheapest i have found compared to $900
Injen
1HG1WW12M259305063
Injen
Originally Posted by taz757
A D17 tranny is a D17 tranny. Someone around here swapped an 04 MT into his 01 because he blew a hole in the casing.
You should be good to go.but like you said a D17 is a D17, but what about D17A2? well i guess it would matter if its vtec or not since they should all use the same tranny system regaurdless of vtec correct?
Injen
I think the trannies are a little different. The EX has just a little be longer gears, as compared to the DX/LX. But that's for the MTs. I'm not too sure how it'd work for an AT ...
Originally Posted by Miata.net FAQ
How does one go about decoding the Miata VIN number?
The typical Miata VIN number looks something like this:
JM1NA3522L0100014
[indent][indent][indent][indent] # 41=2 door
JM1NA3522L0100014
* The J is Japan
o 1 = MI, US
o 4 = KY, US
* M refers to Mazda Japan
o Y = AAI (Mazda USA)
o F = Ford
* The 1 designates vehicle type ie: car
o 1=car
o 2=truck/van
o 3=van
o 4=truck
o V=car [US]
* The NA is the model ID
o NA=Gen 1 Miata
o NB=Gen 2 Miata
o UF=B-2200
o SD=MX-6
o FC=RX-7. etc...)
* The 35 is the body style
o Body style codes:
+ Cars:
# 22=4 door sedan
# 23=3 door hatchback
# 24=5 door hatchback
# 31=2 door coupe
# 33=2 door coupe
# 35=convertible
# 43=2 door coupe
# 46=4 door sedan
# 52=Wagon (used in GLC)
# 62=Wagon (used in 323)
+ Trucks:
# 11=short bed (carb)
# 12=short bed (pre-1986)
# 13=B-series
# 16=B-Series
# 17=B-series
# 21=long bed (carb)
# 22=long bed (pre-1986)
# 31=cab plus
# 32=cab plus (EGI)
# 41=short bed (4x4)
# 42=2 door (4x2)
# 44=2 door (4x4)
# 51=long bed (4x4)
# 61=cab plus (4x4)
+ MPV:
# 52=4 door wagon (4x2 & 4x4)
# 62=4 door van
# 28=4 door van (FF)
* The 2 may be engine code. We're not certain.
* The 2 is a check digit
* The L is model year (L=`90, M=91, N=92, P=93, etc...)
* The 0 is the plant number (0=Hiroshima, 1=Hofu)
o 1=Hofu
o 5=Flat Rock
o T=Edison
* The 100014 is the car number, reset to 100000 and the first car of that year will be 100001.
Or, you can try out Matt Bennett's VIN Decoder.Last edited by infinite012; Jul 5, 2005 at 05:23 PM.
Originally Posted by CiViCPrAnInG2k1
thanks for the help... all i can think of is that the company that wrote the VIN down has somehow messed up the vin number, cause it starts out with 1HG as all of the honda manufactured cars do, the only thing thats messed up is where the EM2 should be located.
Injen
Dawit Melese
Sep 11, 2015 08:25 PM
martinsmartin
Aug 15, 2015 07:34 PM
