My 2001 Civic LX problem..
Old Jun 26, 2005
401CivicLX's Avatar
401CivicLX has a little shameless behaviour in the past
Question My 2001 Civic LX problem..
hey guys, i'm kinda new to this forum, but here is my question.
I have a 4dr 2001 civic lx (bought it used). my problem is this, everytime i drive and go at a speed of 30mph(approx. 28mph and up) i hear this noise... and it's not a noise u can really hear from inside the car... you have to be driving near a fence or other cars to hear the sound echo off. It sounds like something loose (maybe metal bumping against metal) but the thing is, it sounds like something that is powered by electricity... i mean.. it's not just random clanking noise or whatever... it actually has a rhythm. OMG.. it's driving me crazy.. if anyone knows what this problem can be... please let me know. my last resort will be to the shop
Thanks
edit: the noise (to me) sounds like a broken fan... but i'm just assuming a broken fan would sound like this....
If i didn't post in the right section, where would this topic go? I read the forums and this seemed like the best place to post.
Old Jun 26, 2005
diskreet's Avatar
describe in more detail. i have the same car so maybe i can help. i get a weird squeal, pretty quiet, when only pushing throttle about 30-40%. thats all i get i think. tell me what you are hearing and ill try to help you more
edit: actually can that be the air making that sound somewhere in the intake portion of the car? like at the throttle body?
Old Jun 26, 2005
401CivicLX's Avatar
OMG... dude.. i know exactly what ur talkin about with that 30-40% throttle..i hear a squel too. but u can't really tell unless you're the one actually pressing the gas.
But my problem is that when i go like 28mph and up, i hear this sound that sounds like something is rotating... like a broken fan. That's the best way i can describe it.... man.... i wish i could record the sound... To Me it sounds like something that is broken that is rotating. Is there anything that can break that would make a sounds like that?
EDIT: ****... alright, now that u mention the intake.. i took out the filter and put in a new air filter. You know how there are 6 screws u have to take off to get to the air filter? Well i tightened one of the screws too hard and the plastic on where the screw goes in broke.... could that be a reason..? I'm kind of a newb with cars. so i don't know what kind of things makes what kind of noise..
Old Jun 26, 2005
diskreet's Avatar
hmm i dunno. i dont have that sound. only the squeal. glad im not the only one there though. so i guess its normal.
as for your problem does it sound like a fan rotating, or maybe a belt or something. i dunno. i am not huge in knowledge of under the hood, yet. im working on it though.
When (and after) i install my intake on monday after work ill poke around and see if there is anything making the same noise you describe. maybe even tomorrow. ill see if i have the same problem.
edit: if anything like that happened and made noise, it would be a rattling noise. like pastic on plastic. maybe at certian speeds it vibrates enough to rattle. is that it?
Old Jun 26, 2005
l3lackstatic's Avatar
l3lackstatic is an unknown quantity at this point
my car made a sound like that and i thought it was my intake filter, but after i took off my wheels and checked my brake pads, i found that my pads were down, so i just replaced em. check your brake pads
Old Jun 26, 2005
401CivicLX's Avatar
what do u mean your brakes were down? do you mean worn out? I just got my brake pads replaced... so i don't think it could be the brake pads. Damn, i did some research on the noise.. but everyone is complaining about how it makes a noise when they drive in the rain... for ME, it makes a noise all the time. -sigh- wtf is it...
EDIT: yea it might be something vibrating against each other... ****, i'm so confused.. it can be anything. As a side note, the person before me must've had a flattire in the front (right side) because the hub cab is broken and the right front tire is the only new one. I heard changing the ONLY one tire in the front is bad for the car... is that true? because I still have it like that since i've bought it. maybe i should replace all 4 tires...
Old Jun 26, 2005
AzNTiG3R's Avatar
Member
AzNTiG3R is an unknown quantity at this point
I have a 2dr LX and yeah I hear a slight squeal only when I push the gas lightly and when i take my foot off it goes away.
Old Jun 26, 2005
zen_master's Avatar
hmm...no, i doubt that's from your intake..
and fyi....****........grrrr....not suppose to tighen the damn bolts on the intake cover with tourqe wrench........****...stupid me..
i broke 2 out of 6..........one of em kind of bad....doesn't tighen up no more....lol
Old Jun 26, 2005
dalaw's Avatar
Bone Stock!
Yeah i get that squeal or hissing sound from the engine too. Mainly at around 2-3k rpm at part throttle. I like that sound. Sounds kinda like a turbo
Old Jun 26, 2005
diskreet's Avatar
lol i wonder what it is?
Old Jun 26, 2005
Overboost's Avatar
Overboost is an unknown quantity at this point
Have an 02 lx coupe manual here and i hear a vrrrrr sound when i drive it for a while and if i go by a wall like a drive thru and put it in neutral I hear it. It's when my clutch is depressed only.
Old Jun 26, 2005
401CivicLX's Avatar
i drive an automatic.. if i might add. Still don't have an answer to this damn sound. maybe it's the exhaust, maybe it's kinda loose or something... **** i dunno
Old Jun 26, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
ok i know what it is. it is a sound like a whirring that increases when you accelerate right? if so then every civic does this. its like a whiiny noise. like a turbo swirl. its totally normal. if you can hear it when your driving quietly and when you accelerate then its nothing. i drive a 5sp. when i go down a hill i shift to second and roll. i hear the same noise. its a high pitched swirl. no biggie. if its not that say so. if it is its just your engine. nothin at all
Old Jun 27, 2005
401CivicLX's Avatar
Nah, man. I know what everyone is talking about with the low throttle acceleration makin the little pitch sound from the engine.. that got on my nerves too. But what i'm pissed about is this Broken Fan/Clunking/something rotating sound that i hear when i hit 28mph and up. and like i said, you have to be near a wall or something to hear it (with the right side window open). But obviously I'm the only one having this f-ing problem. ****.. so confused..........
Old Jun 27, 2005
Damngoods's Avatar
Damngoods is an unknown quantity at this point
maybe it's your cat-converter cover that's broken so the sound is coming from the vibration of the metal and the cat. It happened to me so i took the cover off the cat and now no prob. Hope this helps!
Old Jun 27, 2005
MajinB's Avatar
ok well if its not that then i have another idea. i had an annoying dragging sound and hitting sound when i braked and i looked around the car and saw that the bumper has a rubber gaurd around the front and it was dragging. look around your car. i am sure you already have. look under the car. jack it up, do everything. and if not then take it to the dealer and let them firgure it out. please tell me you got the 100k extended warranty. good luck.
Old Jun 27, 2005
AzNTiG3R's Avatar
Member
LOL yeah like 2 of my bolts will turn but won't come off and i had to slide the filter out of the box!
Old Jun 27, 2005
CenZ's Avatar
PWIT
ok, you said a hub cap is broken right? well dont you think MAYBE there is air getting cought in the broken part of the hubcap and it is making a funny sound when you drive? here is a easy test. take the hubcap off and drive. if it still happens its not your hubcap. hubcap rotates like a fan, so if a broken fan makes this sound a broken hubcap should too...
Old Jun 27, 2005
401CivicLX's Avatar
ROFL silver02 damn, i didn't even think about that... but i doubt it is.. but imma put some tape on it and test it out...
Old Jun 27, 2005
401CivicLX's Avatar
BTW.... what is a cat-converter?!?
Old Jun 28, 2005
diskreet's Avatar
a catalytic converter is what makes your emissions so clean, and makes us an Ultra Low Emissions Vehicle. its output is water and the exhaust gas you see come out of the car (clean exhaust). It has a catalyst in it which makes the change take place (very very quickly). sometimes you see water when you start but thats usually condensation not from the cat.
Well i installed my intake yesterday. I dont hear the sound you are talking aobut at all. now i just hear the intake, its so loud everything went OK but the AEM SRI isnt exactly a perfect fit! I was not impressed by quality here. Had to fight with the pipe to get it in place!
anyway i dropped a washer somewhere over the trasnmission so I hope that it doesnt break anything lol!
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
