Need some help with lowering a 04
Old Jun 25, 2005
Cjddrum1's Avatar
Ultimate Member
Cjddrum1 has a spectacular aura aboutCjddrum1 has a spectacular aura aboutCjddrum1 has a spectacular aura about
Okay, i was gonna get a 2" drop, but turns out i need a camber kit. SO what would give me a nice drop for a good price thats easy to install. ANy deals or what is a good reliable place to order them? thx
Old Jun 25, 2005
frenum101's Avatar
frenum101 has a little shameless behaviour in the past
i dropped mine 3.5 you only need rear camber kit the front dosent change you can get the rear camber kit from obx for 50
Old Jun 25, 2005
cubanmike26's Avatar
You will need a camber kit rear & front unless you wanna be buying tires every year. I had a 2" drop last year but it'd always bottom out so I went with Sportlines 1.4" drop. SPC makes a great camber kit too for like $140 front & rear...
Old Jun 25, 2005
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
I did a 1.7 drop front and 1.5 drop in the rear and checked my camber. Camber wasnt bad enough to get a camber kit and the only thing i would need to noe is fix my toe.
Old Jun 25, 2005
CenZ's Avatar
PWIT
what setup you got? neuspeed sports?
Old Jun 25, 2005
crazyasian's Avatar
neuspeed springs and koni yellows(bought it off from Skipbarber)
Old Jun 26, 2005
Cjddrum1's Avatar
Ultimate Member
so are camber kits even that expensive?
Ya i think this one guy at a local store tried to rip me off saying springs are 200 for front and 200 for back when isnt it usually like 200 for both? then he tried to charge me 400 on top of the 400 for springs to install it....screw that.
But how much of a drop should i go with to make 18" rims ride close to the body if u know what i mean?
Old Jun 26, 2005
skipbarber's Avatar
to get the most out of your suspension and to get your car aligned properly, you should always use a camber correction kit.
Old Jun 26, 2005
^^I agree...
What size tires do you have?? Are you refering to wheel gap?...if so, it depends on the wheel/tire size combination and the drop you give your car...I myself got 16" wheels with almost stock size tires to eliminate wheel gap, but as a consecuence my tires were rubbing because my car is also dropped; therefore I had to roll my fenders...so you have to keep all that in mind. You can also use the tire calculator to help you...
Old Jun 26, 2005
Cjddrum1's Avatar
Ultimate Member
okay then if i should go wit the camber kit either way would u guys recommend the 2.0 drop?
Old Jun 26, 2005
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
i got sportlines on my 04 and no camber kit. drops good and havent had any problems
Old Jun 26, 2005
frenum101's Avatar
it all depends on what you are looking for like me 1.7 wasnt enugh for me so i went with a 3.5 yes it rides a little rough but fo me its worth it and you are saying a 2 inch drop it all depends on what components you are using
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
bhollie
Sep 22, 2015 11:08 PM
