big problem or not?
Old Apr 27, 2005
nolimitrican's Avatar
nolimitrican is an unknown quantity at this point
big problem or not?
Well Yesterday i was in the highway going like 65-70 mph and all of the sudden this rock it was big but at the same time i thought i was gonna clear w out no problems , well i thought wrong it didnt cleared n all i could hear was da dammm rock hitting everything under the car, i pulled over to the side cause the damn rock didnt came off, i got home n im checking the car the swaybar down there, that holds b0th front tires, well that thing im gonna call it swaybar is loose so i just wanna know where can i get that part? n how much will it cost me? thx
Old Apr 28, 2005
can some1 help me w these problem?
Old Apr 28, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
if you don't know exactly if its the sway bar, how can we help?
Old Apr 28, 2005
yea i just found out it is the swaybar, is just there hanging, i dunno what 2 do
Old Apr 28, 2005
GreatWhite02's Avatar
4 cyllinders are good but 5 is better!
GreatWhite02 is an unknown quantity at this point
if your sway bar is hanging loose underneath your car then you need to get it replaced! Either order one off ebay cheap or go to the dealership and pay full price! You should not do alot of driving without a properly secure sway bar! If you must drive with it loose, take it easy and dont make hard turns or corner really fast! It's not as big a deal as say cutting your brake line and loosing hydraulics but it shouldn't be left like that for an extended period of time!
Old Apr 28, 2005
i got u man, any idea on prices?
Old Apr 28, 2005
Depends on where you get it from! If you are gonna replace the sway bar you might as well get an aftermarket one that is thicker and stronger! Run a search on yahoo and will pull up dozens of results!
Old Apr 28, 2005
Civic04's Avatar
Civic04 is an unknown quantity at this point
need to know what you mean by hanging there on the ends or in the middle if at the ends maye you just broke and link but in the middle you may have broken the mounts. is it in half?
Old Apr 28, 2005
Blahman2's Avatar
pick up grey's endlinks also... He's a member here. You'll need them.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
beveragemp
May 25, 2015 07:11 PM
bsmiley
Apr 27, 2015 01:27 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
