*Update* Turbo the b16 or swap it with a hooked up B18C5 ITR motor
Old Apr 20, 2005
Woot00EPBSI's Avatar
Woot00EPBSI is an unknown quantity at this point
*update*
I got the ITR motor and loving it! glad i went with N/A, thanks for everybody's inputs!
Well i have a 2000 Civic SI and the b16 needs to be rebuild because of hydrolocked not too long ago...well i have a few options really, one being i could rebuild the b16 with the works and turbo it to make about 300whp for everyday driving @11-15 psi, the rebuild will cost me about 5800 installed and turned, or i can get an ITR motor hooked up pushing around 225whp for the 4500 installed and turned. another thing i can do is get another stock b16 and throw a turbo on that making about 260whp @7-8 psi for daily driving...the kicker is i want a running car for the next 5-8 years with no worries, thats why im lookin to getting the B18C5, plus ill have a stock hydrolock b16 sitting here that i could get fixed maybe and sell it to save me more money getting the B18C5. what do u all thing i should do
Old Apr 20, 2005
djmota's Avatar
rebuild the b16 you have for all motor. up the compression a bit install stage 2 cams/springs/retainers IM port the head head use arp hardware hondata tune and enjoy some nice reliable na power. and if you are going to use a cai again use a bypass valve.
Old Apr 20, 2005
dlek00's Avatar
dlek00 is an unknown quantity at this point
if you want more reliability, NA is the way to go.
Old Apr 20, 2005
ragingSPAM's Avatar
I just burnt my tongue
i would go ITR motor...cuz once u hydrolock ur engine that engine is pretty much screwed...i've dealt with hydrolocked engines before and 99% of the time we had to replace the motor...happened mostly on hondas with a cold air intake without a water bypass valve
Old Apr 20, 2005
jhonsok's Avatar
The blackbeauty ES1.
NA with the ITR motor, any forced induction, espeically Turbo there always maintenence involved gahh..lol..i think if you want a car for the next 5-6 years with no problems..the B18 is the way to go. i would anyways.
Old Apr 20, 2005
white2K2EX's Avatar
I sure wish my car was newer
ITR gets my vote.
Old Apr 20, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
b18 can get better compression. But a b16 can be just as powerful. Although the stock torque curve of the b18 is much better than the b16.
Old Apr 20, 2005
eye_see_you's Avatar
let the devil out
ITR all the way
Old Apr 20, 2005
well ive been in an all motor fixed up n/a b16 before...its ok but the money spent on rebuilding it would cost the same as swaping the ITR motor in....but the with ITR it would save me more time and money as well because it wont have to be sent off or anything and plus i could sell the b16 for cheap
Old Apr 20, 2005
white2K2EX's Avatar
The ITR will save you time, money, and, most importantly, headaches. Dealing with building an engine up for turbo can be a real PITA. You'll have more potential down the road if you go with the ITR, too.
Old Apr 20, 2005
Blahman2's Avatar
Why do I have the feeling none of you know anything about the b16 and the b18, other then just what cars feature them.
Old Apr 20, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
b18, cuz then u can turbo it later on
Old Apr 20, 2005
Blahman2's Avatar
If you go B18, B18A/B is probably the best, the B18C1 is also really good, but has a little higher compression, but also has the advantage of VTEC.
Do not turbo a B18C5 it'll go boom.
As for the B16. There about the same as a B18C1 when it comes to boost except for a little less power. Out of the three I would boost a B18B.
Old Apr 20, 2005
HondaLuver's Avatar
Its a celebration bitches!
build a Crv with a gsr head and turbo... its the only way to go
Old Apr 20, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
if you're gonna spend $5800, then save up a little more and get a k20a2
Old Apr 20, 2005
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
B18C5 sounds tasty!!
Old Apr 20, 2005
Blahman2's Avatar
yea, unless you want to turbo it. But N/A B18's rock my socks!
Old Apr 20, 2005
DrOpPeD2k2CiViC's Avatar
DrOpPeD2k2CiViC is an unknown quantity at this point
BOOST is the way to go
Old Apr 20, 2005
5800 is putting a turbo on it and running 300+whp at 12-15 psi...k20a2 is ok but i wouldnt want to spend more time and money on somthing so much slower
Old Apr 20, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
reliability > power
also
6 speed > 5 speed
Old Apr 20, 2005
HondaLuver's Avatar
its so sexy just running threw the gears... all 6 of them... muahhaha
Old Apr 20, 2005
Vantage's Avatar
Vantage should not be trusted
he cant get a k20, he has a EK Si. Now that thats outa the way. Dont build an N/A b16. TO EXPENSIVE, and the results will get u basically wat a stock ITR puts out. Turbo B16 will fly, but id go turbo b18c1 ( GSR). my friend ran 11.89 on a STOCK b18c1, with 11 psi. had no problems. I say easily u will have it 5-6 years if u put it on 7-8 PSI, and it will SMOKKKKEEE any b16a turbo, N/A ITR, or b18a/b turbo. The high compression really doesnt come into effect untill ur up around 15psi.
Old Apr 20, 2005
Marcus's Avatar
And Pimp I got the Juice
Marcus will become famous soon enoughMarcus will become famous soon enough
Turbo
Old Apr 20, 2005
civic01vtec's Avatar
well, a built b16 with turbo and quaife would be amazing.
A all motor ITR is good too......but i love boost
Old Apr 20, 2005
Blahman2's Avatar
Why can't he? Where do you get your facts? The onion? Thats bullshit. A k20 would work fine.
http://www.hasport.com/Products/Mounts.htm
Uh oh! Whats that I see? Is that k-series mounts! UH OH! You can't do that! Why make mounts?! OMG! OMG! OMG!
EDIT: I'm sorry... I was in a mood when I posted this...
Old Apr 20, 2005
ChillinN5's Avatar
ChillinN5 is an unknown quantity at this point
B18, my friend had a built b18c1 with a precision sc61 turbo. Car pulled like crazy. He blew his tranny and while he was fixing it at the guys house he bought the car from....the engine got stolen http://www.honda-tech.com/zerothread?id=1119324
Old Apr 20, 2005
CiViCLiZeD714's Avatar
I'd say B18C5 because there is nothing like a powerful N/A motor.
Old Apr 21, 2005
Vantage's Avatar
Still for the price of a k20 in an Ek, u can easily make a car that runs A LOT faster track times.
Old Apr 21, 2005
2k187's Avatar
2k187 is an unknown quantity at this point
I'd say the B18, though the K would be nice
Old Jun 16, 2005
K motor would be nice...hehe i found out how much it would cost....a little bit too much...
Supramk3
Jun 11, 2015 11:13 AM
vtec_concept
May 24, 2015 10:27 AM
Supramk3
May 11, 2015 07:55 PM
cloudguy
Apr 28, 2015 05:02 AM
Cross
Jan 6, 2002 01:31 AM
