01 to 03 cluster conversion problem... =/
Old Mar 18, 2005
FaZe's Avatar
FaZe is an unknown quantity at this point
My aftermarket HU stopped working (did I blow something? I did disconnect the negative of the battery before starting).
The ABS Light is on (I heard this was normal)
I know Viper was supposed to install it for me, but I really wanted to try this DIY... (the Deck is still under warranty... but is it a plug that I got wrong?)
Old Mar 18, 2005
BIG's Avatar
BIG
I just did a buddies for him....here are some of the problems we ran into, maybe someone knows what we did wrong:
- check engine light stays on (was not on, on old cluster)
- gauges won't turn on unless the car is turned to accessory or on
- gauges won't go back down to the bottom starting position (they are NOT stuck)
Old Mar 18, 2005
dirtySAMURAI's Avatar
I log in from time to time
-not normal
-normal
-not normal
check engine light you could reset yourself.
the gauges going back to the bottom...well open up the cluster and put them all the way down. then reset your cluster. it should work.
all you canadians with your problems doing this conversion. i dont understand why it doesnt work for you guys
Old Mar 18, 2005
_Viper_'s Avatar
ahh man you should have come to see me dude.....
Old Mar 19, 2005
BIG's Avatar
BIG
-not normal
-normal
-not normal
how do you reset the cluster?
there were extra wires that weren't included in the diy....this was an lx to ex conversion, maybe there is a difference from the vp?
Old Mar 19, 2005
FaZe's Avatar
So can anyone help me? the ABS light is on cuz I don't have ABS (can i turn off that light somehow?
and anyone know what's wrong with my HU?
Old Mar 19, 2005
dru106's Avatar
ThE CoRRupToR
I did my conversion and the only thing that went wrong was the fuel gauge. Its always reading empty and im gettin a return signal from the return unit so i think it might be the gauges.......
Old Mar 23, 2005
BIG's Avatar
BIG
same problem!!!!!>........its not your aftermarket headunit bro, your stock one won't work either.....I have no clue what it is
Old Mar 23, 2005
MIVtec's Avatar
MIVtec is an unknown quantity at this point
i blew my alternator last year and my ABS light would not turn off, have you been messing with any major wires? i dunno if that helps
Old Mar 23, 2005
BIG's Avatar
BIG
nothing major
Old Mar 23, 2005
FaZe's Avatar
OK... so I just removed the ABS Led... problem solved...
now.. as for the HEADUNIT
BIG was right.. stock deck won't work either
DECK works in different car...
checked the ACC/RADIO fuse.. fine
I don't think any fuses under the hood affects the radio right?
The wiring for the cluster is perfect... the cluster works great
SO WHAT THE
Old Mar 23, 2005
BIG's Avatar
BIG
I have the EXACT same problem....tonight I am going to see what happes if I connect the deck to a DIFFERENT power source. If I can get it to work on a seperate power source then I'll just leave it like that. Think about it....all you REALLY need the harness for is if you're using stock speakers. If you're not, then you don't really need the harness to work at all.....
I'm going to try the same with the doorlocks
Old Mar 23, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
check the fuse labelled "backup" under your hood in the fuse box.. you mightve shorted out a live wire while working/installing ur cluster or something which caused the backup fuse to blow.. this fuse is used for many accessories throughout the car.. good luck!
Old Mar 23, 2005
FaZe's Avatar
i'll give that a try
Old Mar 23, 2005
BIG's Avatar
BIG
you're the man, nameless....I'm going to check that fuse tonight!
Old Mar 23, 2005
BIG's Avatar
BIG
faze...if you try it tonight let me know.....BTW: tape up the extra wires before you try it...otherwise you might blow it again
Old Mar 23, 2005
dru106's Avatar
ThE CoRRupToR
Wow!! This conversion seems kinda scary lol.......
Old Mar 24, 2005
FaZe's Avatar
the scary thing is: How the heck does the HU stop working when ur working on the cluster... =/
Old Mar 24, 2005
dru106's Avatar
ThE CoRRupToR
lol.....at least ur fuel gauge is working
Old Mar 24, 2005
the headunit will stop working if you disconnect the battery....
Old Mar 24, 2005
Nameless's Avatar
TURTLEonK
^ LOL I hope he knows that
Any luck ????
Old Mar 24, 2005
R1Style's Avatar
Yes we figured it out! Nameless hit the nail on the head!!!
We checked the "Backup" fuse in Big's car lastnight and low and behold it was blown. We replaced it now and the cluster works fine (all the needles reset), the remote power door locks work again, and finally the deck has power and his AVIC-N1 is up and running!!
hondacivic0253
Sep 29, 2015 08:06 AM
260000milesgoal
Sep 25, 2015 07:41 PM
BJB
Sep 14, 2015 11:16 PM
rayman009
Sep 12, 2015 08:30 PM
tomas6791
Sep 11, 2015 06:47 PM
