Help!!! Fogged Headlight
Old Jan 2, 2005
01civicuh's Avatar
01civicuh is an unknown quantity at this point
got my HIDs installed 2 weeks ago...had no problem with my headlights before at all..but after gettin the HIDs installed, my left headlight fogged up!!! anyone kno how to DEfog them w/o taking apart the headlight...it was a b*tch puttin them together when i blacked them out..dont wanna have to do that again...ne suggestions n opinions on how to get rid of the foggin with taking out the headlight??????
Old Jan 2, 2005
D5cIvIc's Avatar
is it foggin up on the lens? or where hte HIDS reflect off of(the back).??
Old Jan 2, 2005
K20me's Avatar
Take out the headlight and I believe there are 3 holes in the back of it. Use a blow dryer to dry it off. I've done that once and it evaporated all the water. Make sure to reseal the headlight too.
Old Jan 2, 2005
01civicuh's Avatar
its foggin up on the lens...say for example...u rub the moist from the outside of the headlight...it wont come off cuz its from the inside...
Old Jan 2, 2005
01civicuh's Avatar
"anyone kno how to DEfog them w/o taking apart the headlight..." i dont wanna take it apart...so i wouldnt have to reseal it...trying to stay away from that n still get it DEfogged...
Old Jan 2, 2005
PacSmalls's Avatar
PacSmalls is an unknown quantity at this point
maybe pull off the rubber things on the inside of the engine bay that are there to keep water etc out around the wiring and let it air dry...beats me
Old Jan 2, 2005
02civic_rida's Avatar
^^^ yea thats actualy a very good way to do it... but it depends on where the fog is..... I have fog right above the lil circle to the right and it wont come out, its like its to tight of a spot for it to come out..... Plus... If u leave your car out in the sun and take off that lil rubber piece that should help to...... good luck mang.
Old Jan 2, 2005
ChiNkYx1's Avatar
ChiNkYx1 is an unknown quantity at this point
just take out your headlight and run a heavy bead of clear sealant on it, thats what i did when mines fogged up and no more fog
Old Jan 2, 2005
Cocky's Avatar
Cocky guys kick ass!
just leave it alone, it goes away after a while. mine have done it before.
Old Jan 2, 2005
K20me's Avatar
You don't HAVE to take it apart with the way I told you. That's why I said there's THREE holes in the back. I TOLD YOU to reseal it because there's a part where you didn't seal it entirely. Anyway do whatever you want I'm done with you.
Old Jan 2, 2005
ImPulse's Avatar
I suggest you take the TYCs apart:
Take all the bulbs out of the TYC, Set the oven too 260, turn it OFF, place the TYCs in there for 5-6 minutes
Take the lense off, and clean the inside of the lense, then put it back together
Then take water proof silicone (kitchen and bath II) and put 2 layers of the silicone around the seal (where the lense meets the headlight).
__________________________________________________ _
Or... You can just take the headlight off and get the water out by using a hair dryer... Problem is, you will always have a water mark inside the headlight. And in time, It will just look really ugly. Then add a layer of silicone where you think its needed...
Anyways, Good luck with that... I suggest taking them apart though (a water spot would constantly **** me off)
- Jay
Old Jan 3, 2005
dru106's Avatar
ThE CoRRupToR
crack open the headlight wit a hammer
Old Jan 3, 2005
exclusive_vtec's Avatar
seal it again and again and again.
UltraHDGames
Jun 8, 2016 05:16 PM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
