slwoing down
Old Dec 28, 2004
eddiechaps's Avatar
i love my morreale
slwoing down
is it bad for the auto tranny if you throw it into neutral while slowing down at stop lights & or stop signs?
Old Dec 28, 2004
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
lol
Old Dec 28, 2004
robo1040's Avatar
i dont see why it would be bad?
Old Dec 28, 2004
eddiechaps's Avatar
i love my morreale
well i did it once cause i thought i was gonna hit someone & it helped me stop a little bit easier. so idk? if i do it a lot wil it mess up the car?
Old Dec 28, 2004
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Its like shifting out of gear in a stick...no big deal as long as you dont jam it into gear at high RPMs. Downshifting into D3 D2 would have helped more and is essentially the same as downshifting a manual. Just make sure your at a sutable speed for those gears and your fine.
Old Dec 28, 2004
playa6tnine's Avatar
playa6tnine is an unknown quantity at this point
it actually saves gas a little. it doesnt harm the car at all. i keep it nuetral when slowing down or stopped at a light. less rpms = more gas milage, so in nuetral u dont use any rpms.
Old Dec 28, 2004
slvrcivic's Avatar
slvrcivic will become famous soon enoughslvrcivic will become famous soon enough
actually this was in the paper about a month ago. They had auto makers explain the differences, etc between two auto cars. One that put the car in neutral on slopes, stoplights, etc. One that always kept the car in gear.
Automakers found that the car put in neutral faced more trasmission problems later, and actually had worse gas milage every fillup compared to the one that left the car in gear.
Don't quote me, but they said when the RPMs are misleading when your car is put into neutral, and that it actually is higher than what the tach.
Then it said the car will actually not use gas as effiecently as when the car would be engaged constantly in a gear. They compared it to a car being driven on cruise control. The less the tranny goes up and down, the better.
So it's actually better to be at 3k constantly then be at 3k, then 1k, then 3k, then 1k, etc. Every test proved it. And it showed significantly more wear on the transmission.
So I wouldn't do it if I were you.
Old Dec 28, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
when the car is stopped at the stop sign why would you have the car on gear fo like 50 seconds which is what a regular red light lasts for?
you should put it to neutral whn you are stopped that way it doesnt wear the clutch cylinders or any other things.
also when you are slowing down if you wanna save gas dont downshift just put it into neutral and brake like you would with an auto car
edit:sorry i didnt read well you had an auto man im sleepy i need to go to sleep disregard my post.
Old Dec 29, 2004
pbfoot's Avatar
just give up dude...stop pretending you have a manual.
Old Dec 29, 2004
TeRRoRiFiC35's Avatar
Type Skivic
From: Old Bridge, New Jersey/ West Virginia University
TeRRoRiFiC35 is an unknown quantity at this point
ull mess up ur tranny if u keep doin it. my friend did the same thing in his accord till he blew the tranny
Old Dec 29, 2004
I FuSe I's Avatar
I FuSe I has a little shameless behaviour in the past
What needed to be said, has been said. This thread can now be locked.
Old Dec 29, 2004
Cocky's Avatar
Cocky guys kick ass!
i think his title says it all.. by the way.. ibtl.
Old Dec 29, 2004
sw388integra's Avatar
whats wrong with keepin it in gear and applying the brake..
Old Dec 29, 2004
dirtySAMURAI's Avatar
I log in from time to time
when you stomp on the brakes from any gear higher than 2, the auto tranny SHOULD downshift for you. it's the same tactic that standard drivers use called heel-toe. downshift the car, slow down quicker.
an added benefit to this would be acceleration from a lower gear at high rpm is quicker (on honda's, at least) than acceleration from higher gear at low rpm.
Old Dec 29, 2004
xX03EXx's Avatar
Sweetest Dude on 7th Gen
They gave it the "d" for a reason, if it were better for the car, they would have told you when you bought it to put it in neutral.
Old Dec 30, 2004
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
ITs better for ur gas, its Worse for ur brakes because u dont have an extra force slowing ur car down (ur engine)
Old Dec 30, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
Sob wtf do that for?
Old Dec 30, 2004
AzNmiKex215's Avatar
2k1civic.com O. G.
if it was better to have the car go in neutral when comming to a stop, i think the honda engineers would have designed the transmission TO DO SO AUTOMATICALLY.
