ppl with vis oem cf hoods
Old Nov 19, 2004
18rbetter's Avatar
18rbetter is an unknown quantity at this point
dont flame...but are hood pins needed that bad? like will the hood blow off down the interstate? who all dont got hood pins and do u have any probs. thx
Old Nov 19, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I don't have a CF hood, but I'd get a set just to be safe.
Old Nov 19, 2004
2k3kansasEX's Avatar
Got the broccoli in my back pocket
2k3kansasEX is an unknown quantity at this point
From what I have read as long as it the oem and you can use the OEM latch and all you ahould be ok. I dont have one, but I'd kinda like to know the same thing. Thats just what I have read.
Old Nov 19, 2004
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
I wouldnt say that they are nesessary b/c vis does provide a hood latch, but I would consider them reccomended. They will add security plus they look awesome.
Old Nov 19, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
VIS states that if you use their hoods, you will not need to use hoodpins. I would reccomend using them though, 120 mph+ runs can get a little windy
Old Nov 19, 2004
AdamOSU's Avatar
AdamOSU is an unknown quantity at this point
Ya, when I had mine on without hoodpins it scared me to death driving down the highway. There is nothing like seeing your hood flapping in the wind. It was just not stable enough for me. Hood pins definitely solved that. By the way, I had a VIS oem cf hood on my 02 ex.
Old Nov 19, 2004
incubus7d's Avatar
I Wanna Die Like God on the Cover of Time!
incubus7d is an unknown quantity at this point
I dunno i had a VIS and no hood pines it worked fien for me, their the best hood i never had any problems
Old Nov 19, 2004
18rbetter's Avatar
thx for the input guys....just switched to this hood from a kaminari and I dont think ill use the pins cause it dont looks as clean
Old Nov 19, 2004
D5cIvIc's Avatar
i have one and i'm not using hood pins. the reason why it shakes is becuz you have to adjust hte latch and the black rubber thingies in the engine bay to make your hood sit tight. but get them if you drive over 100 all the time, which you shouldn't by the way but yeah. i dont' have one on mine but i did have them before. same thing, but is recommended if your that scared
Old Nov 19, 2004
macH's Avatar
macH is an unknown quantity at this point
had one for more than a year and half and never needed hood pins. just make sure it latches firmly and ur fine.
Old Nov 19, 2004
SLO REX's Avatar
250+ awhp Stage 2
I have hood pins on mine hood. I don't think you really need them but they kind of give them a distinct look.
Old Nov 19, 2004
eklipz's Avatar
ive had my hood for over a year, no problems. But...it does scare me at 80+....it wobbles bad
Old Nov 19, 2004
AdamOSU's Avatar
Yeah I dont care how good you latch it, it is going to wobble at high speeds obviously more than your stock hood. If you are comfortable with that, then don't worry about hood pins. Sure, people don't usually have problems with it flying off or anything.
Old Nov 19, 2004
itskalvin's Avatar
itskalvin will become famous soon enough
2 weeks ago while going up north i decided to top out my car since it was a straight road and no cars, i topped out my car going 127 and i forgot i even had a CF hood, i was going 100+ for a good 20-30 seconds. i wouldnt worry abot it to much. o yah and mine is VIS also
Old Nov 19, 2004
cdmx's Avatar
negative...hoodpins are not necessairy
its just the hooditself...you never know if it was produced with the Exact same quality as the one before it...
i mean some are better/stronger than others
I myself have driven my hood to 120+mph and there was no shaking ratteling or ripping off of any kind
(for research purposes ofcourse)
Old Nov 19, 2004
cdmx's Avatar
Thats not good!!
SidCivic
44
Oct 12, 2017 03:39 PM
SidCivic
Oct 3, 2015 06:00 AM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
Pier7866
Sep 6, 2015 06:54 PM
