fogged up light
not so fly, yet slow and enjoying it
fogged up light
i got my car back from the shop and i find that the left headlight is all fogged up/cloudy after a bit of driving. anything i can do? i wanna clear them out so could this be a good opportunity? that and the right side is definitly higher than the left, how do i align them? anyone in the tampa area could help?
Originally Posted by dru106
take off the rubber cover and bulb and let cool air in. Then it should go away.
So you got the single projectors?and u have a coupe?go to honda and pick up the sedan headlight sockets.they should fit and stop the fogging.I had the same prob till I did this and now..... Poof..... No fog.
i learned that if you use a hair dryer it will leave little water spots on the inside of the clear lense. If i was you i would clear them, and in the process wipe off the lense with a rear soft rag.
one of my lights was fogged up pretty bad after the heavy rain. thanks to me doing the DIY clearning headlight mod and me not sealing it well enough. i just opened them up again and cleaned them out and painted them all nice. i resealed them this time with a window/door silicon so hopefully they wont have the problem again. but if you never opened your headlights, i'm guessing it's getting moisture from the back where the bulb is, check the rubber cover around the bulb for damage or improper seal.
Go to honda and pick them up if u have the single halo projectors
ok here they r.# 33302-s5a-a01 and #33304-s5a-003 u will need two of each. They r like 9.99 each so ur lookin @ 40 bucks plus tax.but it will stop the foggin on the single projectors.
i know i had to use like 3 packs on mine
