Engine Mods
Old Aug 18, 2004
jayp25's Avatar
jayp25 is an unknown quantity at this point
Engine Mods
I was looking online at www.raceeng.com and they have pistons and rods for the D-17 motor but what kind of gains do you get from replacing these if anyone can shed some light on this.
Old Aug 18, 2004
Project2k2's Avatar
Rods or more for reliability not so much gains. As for the pistons, you will see a slight improvement if you get higher compression pistons such aas 10.8:1 or 11:1. That's if you are running a N/A setup. If you are boosted lower compression such as 8:1 are good. You will see the most gains if you are boosted and then drop the compression, as for raising the compression on a N/A set up, you MIGHT get somewhere around 5-10 horses depending on other mods.
Old Aug 18, 2004
02sleeper's Avatar
Boosted Auto Sedan Project In Progress
02sleeper is an unknown quantity at this point
8:1 is a little to low 9:1 is perfect for most semi high boost set ups
Old Aug 18, 2004
gotti's Avatar
what size in mm do we need?
Old Aug 18, 2004
Project2k2's Avatar
bah UI looked that up before...I know it's a little bigger then the D16 somewhere around the 74 area but not sure let me see if I can find it.
Old Aug 18, 2004
Master's Avatar
Banned by Admin
ibtm should this not be in other products and parts?
Old Aug 18, 2004
jayp25's Avatar
Thanks man for the info.
tylerginevan
Apr 27, 2015 12:29 PM
CivicVoz
Apr 16, 2015 08:07 PM
JumpingBean
Nov 12, 2001 05:42 PM
colombianDXcivic
Nov 8, 2001 05:26 PM
