DIY Ground Wire Kit Pics
Old Jun 22, 2004
CivicHX01's Avatar
I pieced together this ground wire kit with the help of this thread
http://www.7thgencivic.com/forums/sh....php?p=2094239
on to the pics:
Old Jun 22, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
looks pretty nice.. im have to get red wires too
Old Jun 22, 2004
Quijano187's Avatar
The Evil Genius
did you notice a difference or is it all bs? i still like it for show... what gound kit did you get? holla back
Old Jun 22, 2004
d17a2outlaw's Avatar
d17a2outlaw is an unknown quantity at this point
got a little too happy with the red spray paint? ground wire looks good.
Old Jun 22, 2004
CivicHX01's Avatar
i did notice a difference... there is a bit more throttle response especially in 2nd gear... before there was a bit of lag in 2nd around 2-4k rpm but now that lag is gone... and my radio sounds better too, the sound is more crisp...
others also say that gas mileage increases and the headlights get brighter but i haven't checked those yet...
i sprayed those a long time ago when i first got the car, i didn't even have an intake yet... its those times when you want to do something to your car really badly and you don't have enough money for the real mods... a $3 spray can of paint was affordable at that time...
Old Oct 21, 2004
AceKicker's Avatar
AceKicker is an unknown quantity at this point
So what is up with the two distro blocks why did you go with two of them instead of just one.
Old Oct 21, 2004
wonderz's Avatar
wonderz is on a distinguished road
'cause most distro block comes with 4 outputs.. and you might want to ground more than 4 points. thus 2 distro blocks.
Old Oct 21, 2004
AceKicker's Avatar
OK im an idiot. thank you for clearing that up for me lol.
Old Oct 21, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Looks great - gotta get me some red wires...
Old Oct 21, 2004
CivicHX01's Avatar
exactly... i have 8 grounding points so 2 blocks... thats why there are 2 wires coming out of the negative terminal of the battery, 1 to each block...
left block
1. passenger shock tower (stock grounding point)
2. thermostat -> then replace the stock wire that connects the thermostat to front tie bar
3. throttle body
4. tranny
right block
1. firewall
2. driver side shock tower (i used the hole under the clutch reservior)
3. alternator
4. valve cover
Old Oct 21, 2004
armjr2's Avatar
armjr2 is an unknown quantity at this point
where did you connect the wire to the alternator cuz I didnt see a spot to connect it to. and same with the throttle body
Old Oct 21, 2004
Ledbelly's Avatar
Im the man in the box
You should sell this
Old Oct 21, 2004
CivicHX01's Avatar
check this thread...
for the TB i connected it here
for the alternator
thats not my car but i connected it the same way and followed that DIY...
Old Oct 21, 2004
exclusive_vtec's Avatar
very nice!
u see or feel a difference??
Old Oct 21, 2004
CivicHX01's Avatar
Originally Posted by exclusive_vtec
very nice!
and also, since then i have checked the gas mileage and it did increase by like 1-2 mpg... i used to get like around 30-33 mpg... but now i get like 33-39mpg (depending on how i drive).... but keep in mind, i've also added denso iridium ik20 spark plugs and switched to mobil 1 synthetic 0w20 since then...
so those 3 things (ground wire kit, plugs, and oil) have all contributed to the ~5 mpg increase...
Old Oct 22, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
its the oil. mine increased on the oil too, but i drive it like i stole it so its still going down...
Old Oct 22, 2004
Civicly02's Avatar
where did you find it? locally andrew?
Old Oct 23, 2004
CivicHX01's Avatar
the ground wire kit? i pieced it together buying parts from different places... i got the distro blocks and terminals from ebay, wire and ring terminals from gadgetpros.com
then i got some sandpaper and sparkplug grease to ensure good contact...
Old Oct 24, 2004
Mr.Modify's Avatar
very nice
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Lopes101
Jun 7, 2015 08:04 PM
dinsum
May 28, 2015 09:30 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
ImmortalEX
Nov 8, 2001 09:52 PM
