Help me decide.
Old Apr 23, 2004
civic2uner's Avatar
Question Help me decide.
I can't decide what i want to do next. Should I get an Altezza grill, AEM short ram intake, or leather door panels?
Old Apr 23, 2004
Mr.Modify's Avatar
hmmm honestly IMO neither....any other ideas?
edit: well since you asked i would have to go with the Altezza Grill
Old Apr 23, 2004
civic2uner's Avatar
100$- what would you do?
Old Apr 23, 2004
civicvtec1ps's Avatar
Search and Learn
Save up more and buy lowering Springs.
Or
RSX 19mm Rear Sway bar with ES Sway bar Bushings.
Old Apr 23, 2004
civic2uner's Avatar
"RSX 19mm Rear Sway bar with ES Sway bar Bushings."
What is that?
I almost bought eibach springs but i wall afraid of the alignment and the negatice camber. the tire shop said i woud never get it aligned right.
Old Apr 23, 2004
abmerop18's Avatar
Jam out with your clam out.
What is that?
here is the 5 step process to getting a good alignment with lowering springs that is fool proof:
1. buy springs
2. install springs
3. buy front and rear camber kit so your camber can be adjusted and it wont be negative
4. install camber kit
5. go get alignment
5. drive away from alignment shop happy because you have and never will have any alignment problems or bad camber since you got a camber kit
Old Apr 23, 2004
civic2uner's Avatar
that sounds like a lot of money. i heard camber kits runs into the 200's
Old Apr 23, 2004
JayFReaZy's Avatar
camber kits go for about 130-140 for both the front and back I believe.
Old Apr 23, 2004
civic2uner's Avatar
that aint too bad. what would you do with 100 extra dollars?
Old Apr 23, 2004
civic2uner's Avatar
come on now, someone, anyone
MarkieMark
26
Aug 17, 2006 08:46 PM
0100010
Jan 19, 2002 07:15 PM
