My new push button start
Old Jan 10, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
Talking My new push button start
this took a while to hook up cause i was using too small of wire for my splice to break through the insulation but its working now
Old Jan 10, 2004
gotti's Avatar
yeaaaa thats hot
Old Jan 10, 2004
JayFReaZy's Avatar
sweet!, how hard is it to DIY for the push button start? Also, can you still turn it on manually with the key if you would like?
Old Jan 10, 2004
WannaBFast's Avatar
its pretty easy.. i woulda done a diy.. but i made quite a few mistakes...
just remember this... black/white wire is starter, white is constant power, ground anywhere, and use the black/yellow wire for your ignition source
that being said, you should use the yellow scotch locks with 12-14 gauge wire to have it so you can still use they key.. no cutting of wires is necessary
i cut mine because i want to have to use the button
im gonna put in a switch so that i can turn of the damn light when my car is already running so ppl dont think they can push the button when the car is running
Old Jan 11, 2004
7thGenerasianCivic's Avatar
congrats man! I see you were having troubles at first but you got it at the end. Good job!
Old Jan 11, 2004
slappyhoohah's Avatar
i need to do this... i've had the button sitting around since the summer but i dont want to screw anything up. If its easy i might just give it a try
Old Jan 11, 2004
CarbonFly's Avatar
Welcome to the family..............
Old Jan 11, 2004
Unleaded's Avatar
Unleaded is an unknown quantity at this point
cool, but if were to do this i would mount it on the left side near the coin tray so that people don't mess with it while the car is running.
Old Jan 11, 2004
CarbonFly's Avatar
^^ On the contrary, I put it there so that people could mess with it. It's great for shows when you show it to people and they are like "That's so cool!" So I let them sit in the passenger seat and they get to start the car up. It helps generate interests in the car.
Old Jan 11, 2004
WannaBFast's Avatar
well im gonna have a switch so i can "kill" the switch when the car is running... cause when the car is on... the button stays on...
Old Jan 11, 2004
Unleaded's Avatar
yeah, i know that the point of having this thing is to show it off, but i am under the assumption that it is bad to push the button again while the engine is running. like when you crank the ignition on a running car and it makes an awful sound. i think the S2000 has it on the left side for a reason.
Old Jan 11, 2004
guamcivic2k1's Avatar
YoUnG N SuXsExFul
nice job...that's nice..makes me want to get that too
Old Jan 11, 2004
R3DL1N3's Avatar
where do you guys put your cig outlet? or do you even keep them?
Old Jan 11, 2004
joescivic02's Avatar
Abercrombie and Fitch
they don't make these for 5 spd, do they? if so, wouldnt it be better in a manual since you have to engage to clutch to start?
Old Jan 11, 2004
WannaBFast's Avatar
i have a 5spd.... yes you have to press the clutch and the button to start, and i havent gotten as far as to relocate the 12v socket yet.. but when i do, you will know
Old Jan 11, 2004
Yukonart's Avatar
Yukonart will become famous soon enough
Of course these are made for 5-speeds. . . .
Every S2000 on the road has one, and they're all manual transmissions.
Old Jan 11, 2004
WannaBFast's Avatar
but the s2000 is a 6spd...
Old Jan 12, 2004
Yukonart's Avatar
Good point.
lease:
Old Jan 12, 2004
CarbonFly's Avatar
I threw mine away. What do I need it for? I don't smoke and my radar detector & cellphone charger are both hardwired.
Old Jan 12, 2004
but my point is, wouldn;t it be better on a 5 spd because if you push that button again, it wouldnt do anything right? i mean you have to engage the clutch to start so.........
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Laurenhunter7
May 10, 2015 01:09 PM
ZSKCivic01
Jan 5, 2002 12:15 AM
black2k1vtec
Dec 6, 2001 09:49 PM
nickfn
Nov 30, 2001 11:13 AM
