Adjusted my Headlights (nothing big)
Old Sep 8, 2003
dustin_samuel's Avatar
dustin_samuel is an unknown quantity at this point
Talking Adjusted my Headlights (nothing big)
My driver's side headlight was always brighter than the passanger's, and when I bought mtec hyperwhites, I finally got tired of it. I read the DIY's on the site and adjusted them and I love the way they look when I'm driving. I'm really surprised. I lowered the driver's side a little bit and then raised the passanger side to match it. Nothing major, but what a nice simple tweak.
Old Sep 8, 2003
Mr.Modify's Avatar
do you have to take off that rubber sealer thing in order to adjust them or can you just pop your hood and then adjust them without taking anything off because i have been wondering how to do this?
Old Sep 8, 2003
JayFReaZy's Avatar
Re: Adjusted my Headlights (nothing big)
Yea, I know how ya feel. When I first had my halo projectors, the same thing happend to me. Most of my light was on the driver side, then I adjust the passanger side a little bit to aim it straight. Then, viola, decent lighting!, lol. Not as good as stock, but definetly way better than b4.
Old Sep 8, 2003
At first, I thought it was going to be hard to adjust them. It's SOOOO easy. You don't have to remove anything. After dark, just park about 20 ft (if you can) away from a garage door, white wall, or something like that. Little things to obviously consider...park absolutely perpendicular to the wall to avoid the angle scewing the pattern and park on a level plane with the wall. *NOTE: This is for a 2002 Sedan and I've read others are different.* Open your hood and if you look straight down at the back of your headlight assembly between your actual headlight bulb and your parking light bulbs, you'll see a groove leading down to a gold thing with teeth on it. Take a small flathead screwdriver and turn it to vertically adjust your headlights. I can't remember which way adjusts up or down, you'll just have to experiment.
Old Sep 9, 2003
nuffsed's Avatar
thanks... i gotta try that... my TYCs are badly aligned
MamaBear2015
49
Sep 29, 2015 01:12 PM
shaejb15
Sep 3, 2015 01:35 PM
wingsfan19
15
Sep 2, 2015 02:15 AM
JetsterDajet
Aug 15, 2015 08:07 AM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
