Just installed the CATZ HID High/Low Kit!
Old Aug 2, 2003
JayJay's Avatar
JayJay is an unknown quantity at this point
4500K CATZ HID High/Low Kit
I put the little caps on the mounting bases this afternoon. The lights don't look like bats anymore.
Reflector Hood attached to the Mounting base
Old Aug 2, 2003
DaZeD's Avatar
Don't Hate. Just Envy.
it looks like the the bat signal, but that nice
Old Aug 2, 2003
civicvtec1ps's Avatar
Search and Learn
very nice.
how was installation?
Old Aug 2, 2003
TOOLOWCIVIC's Avatar
Hey I just installed mine this afternoon too. They are beautiful. My only problem is that they are too bright. Everyone has been flashing there highbeams at me even a cop. So I flashed my high beams back. Damn my low beam lights up the whole street and when I put the high beam it looks like daylight. They are so bright. Im kinda worried Ima get pulled over.
Old Aug 2, 2003
JayJay's Avatar
The installation took a lot longer than I thought.. about 4 hours. It wasn't difficult, but there was so much wiring to do. Also, it was really hot and humid outside.
Old Aug 2, 2003
Yeah they do kinda look like that. Have u driven it around at night and have people been flashing there lights at u??
Old Aug 2, 2003
JayJay's Avatar
I haven't really driven my car yet.. just around the block. They are really bright! When I first turned them on at night, I was like "whoa!". They are a lot brighter than the SilverStars I had before. I also like how it starts out bluish and then becomes white.
Old Aug 2, 2003
Yup I love it. I just hope that I dont get a ticket or anything for it cus damn I really love this kit. Its the damn best.
Old Aug 2, 2003
Scott2055's Avatar
Scott2055 is an unknown quantity at this point
TooLOw did you aim them at the same height as your stock lights? Maybe they're aimed too high and that's what's causing the problem w/ others flashing you. If they're aimed the same as stock, maybe try going a bit lower to avoid this?
Old Aug 2, 2003
dragoon's Avatar
angle them down and to the right a bit if you can
Old Aug 3, 2003
I think thats what the problem is. I love them though cus I can see the ground really good, the sides, and even higher. They are very very good. I am so happy with them. If anybody wants to know if they are worth yes they are. Very worth the money. So do I adjust them by the way the manual says since I have the stock housings I've never had to aim them so how so I do it??
Old Aug 3, 2003
RSDCivic's Avatar
RSDCivic will become famous soon enough
that looks nice... feel sorry for people who pass you comin the other way lol, definitely gonna look into that kit...
Old Aug 3, 2003
This kit is the best. Its brighter than most HID kits I've seen.
Old Aug 4, 2003
bboysushi's Avatar
bboysushi is an unknown quantity at this point
where did you get it, and how much for one?
Bboysushi
Old Aug 4, 2003
JayJay's Avatar
I got mine from Liteswap.com for $528.99. The HID Kits are no longer displayed on the website due to the ban, however you can still get them by sending an e-mail to info@liteswap.com.
Old Aug 4, 2003
civicdude's Avatar
Nice crisp clear light
Old Aug 4, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
guys guys guys... it NEVER seems like you have clean lines on your HID... seems VERY sloppy... HID when done correctly should be a clean like at the break off... ever seen an S2000 when it pulls up behind a car at night? CLEAN line with color in the break off... BEAUTIFULL! you are all buying universal kits that arent designed to fit in your housings, HID is vERY sensitive to the distance beetween itself and the edge of the lamp, it changes A LOT on the beam pattern... you should go out and get a quality kit designed for you, not this universal mass produced stuff.. i payed like $100 less, and my kit is SO much cleaner than that.... Hella baby, HELLA
Old Aug 4, 2003
JayJay's Avatar
futurersxswap,
Can you post pictures of your HID setup?
Old Aug 4, 2003
My friends got hella on his car. It looks pretty good but I think the Catz kit that I have is cleaner than his.
Old Aug 4, 2003
FALKEN's Avatar
Civicforums Junkie
nice set-up!!
Old Aug 4, 2003
islanboun's Avatar
islanboun is an unknown quantity at this point
JayJay, I just got mine today, did you end up having to remove the bumper/housings from the car to put your bulbs in? Also, I just talked to eric(liteswap) he reminded me that even though we already have covers on the front of the bulbs stock, use those little caps that came with the kit it should sharpen your beam pattern.
Old Aug 4, 2003
JayJay's Avatar
islanboun, I did remove the front bumper just in case I wanted to mount the ballast units or the high-low solenoid controller somewhere down there. However, I did not remove the headlight housing assemblies. I ended up putting the ballast units and the high-low solenoid controller on the sides of the engine bay. Thus, I didn't have to remove the front bumper at all.
When I have some free time and if it's not raining, I'll try using those little caps as well as relocate the hardware and organize the wires. It was so hot on Saturday and things were taking a lot longer than I had expected, I just did what I could to get it working.
Old Aug 4, 2003
islanboun's Avatar
Thanks,
P.S. If it was that hot in NJ, then you can imagine what I have to deal with tomorrow when I put mine on in Orl,FL
Old Aug 5, 2003
Damn it was hot here in Houston when I was I got mine put in this Saturday.
Old Aug 5, 2003
islanboun's Avatar
Ok guys mine are up and running. I used the caps without removing the housings,they fit just fine. I dont understand what the big deal is about people saying not to pu HID in the stock housings, mine came out great. I even got a compliment on my way home. I just have to aim them later on tonight, I assume that is done with that little hex screw ?
Old Aug 5, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
All this talk about HIDs makes me want to get rid of my projectors and paint my oem lights gunmetal and get a hid kit.
Old Aug 5, 2003
Scott2055's Avatar
You had better make that decision quick man. The govt. is banning all sales of aftermarket HID kits after August 15th. I wasn't gonna get HID's till after my rims but i had to get them first or i wouldn't have been able to get them at all.
Old Aug 6, 2003
JayJay's Avatar
islanboun,
Can you post some pictures of your HID's against a wall?
Old Aug 7, 2003
islanboun's Avatar
Yeah I just got to finish off the roll of film and I'll get them up(I whould use a digicam but my Canon Elan 7e SLR blows away most digicams)
Old Aug 7, 2003
A lot of people have been saying that my hids look great on my car. They dont look out of wack like some people say they would with stock housings. Their great.
