EPS Install
Old Aug 21, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
Talking EPS Install
I had the electronic power steering (EPS) from a Civic Si installed in my car today. Here are a couple pix:
Josh (drivetofast) did the install. Highly recommended!
Old Aug 21, 2005
_Viper_'s Avatar
so what is it like????????
Never realy thought civic could have that
Old Aug 21, 2005
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
I knew it was possible, just heard eps robs the feel of driving. Doesnt make sense, cause I really dont know what it means either, I just read it off a hondatuning magazine. Tell us, do you like eps or not
Old Aug 21, 2005
It feels great! Pretty much like hydraulic p/s. Far better than being without any p/s.
Old Aug 21, 2005
I think it is pretty much the same. The biggest benefit is you don't have the parasitic loss like with hydraulic p/s.
Old Aug 21, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Well.... having driven the Si, I hated the EPS, but something is better than nothing..... why did you originally pull the HPS?
This may/may not be good to know for K swappers... it saves the hood wacking step for the pump.
Old Aug 21, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
So... what's all involved in doing this?
Old Aug 22, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I've driven Josh's car and to me, EPS feels exactly like HPS ...
Old Aug 22, 2005
I couldn't use the HPS with my stock hood. There wasn't enough clearance, even if you cut the under brace like some members have. I don't know if Honda made some changes to the engine bay for the '04-05s, or if Hasport changed their motor mounts, but the p/s pulley sat so high that I would have had to cut a hole through the engine hood to make it fit. It wasn't as simply as tryin to free up an inch or so. From what I was told, the top of the pulley was a couple inches above the engine bay.
Old Aug 22, 2005
You need the following parts from an Si:
electric power steering rack
"control module"
all applicable wiring harnesses
From what I observed, you simply:
remove the hydraulic power steering rack
install the electric power steering rack
"splice-in" certain wires to the ECU
run a constant power feed
Old Aug 22, 2005
The install was done yesterday and I have only driven the car a couple of times. However, I can't notice any difference. If there is any, it is subtle.
Old Aug 22, 2005
tinman's Avatar
"control module"
Thanks! I'll have to look into this...
Old Aug 22, 2005
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
i can do it for anyone $1000 instaled like i did for quick silver
Old Nov 1, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
I wish someone would post more information on just *WHAT* you ****ing need to do to convert to EPS
Old Dec 16, 2007
kalonov's Avatar
kalonov is an unknown quantity at this point
Re: EPS Install
Hey guys,
I just bought a 2006 Honda Civic Si with flood damage.
And the power steering was not working on it. Brought it to a dealer and they had me replace Steering Rack, and Steering Wire Harness.
And guess what, after spending $2K on it the steering is still not working.
Any idea what else could be damaged by water to make the power steering not work? They said the EPS module is working fine. Do you think I should still go for it and replace EPS? Can I do it myself or it requires a re-programming once replaced with a new one?
Dealer said, the ECU is not giving any error codes even with the steering not working and EPS connected. Any suggestions on this greatly appreciated.
Cheers,
Mr. K
Old Dec 16, 2007
Rennen's Avatar
New Mod on the Block
Re: EPS Install
go back to the dealer and make them fix it. if you spent $2k the problem should be theirs to fix, not yours.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
