Rear trailing arm bushings
Old 04-17-2014
GM75's Avatar
GM75 is an unknown quantity at this point
I'm having a hard time with my rear bushings.
http://www.hondaautomotiveparts.com/...s5p501_b29.png
is it not possible to buy the front trailing arm bushing or the upper arm bushings? the ones with the tabs sticking out of them that attach to the frame (within 14,15 & 18)
thanks
Old 04-17-2014
Prelude Owner
GolNat's Avatar
Re: Rear trailing arm bushings
Are you referring to the parts that are in this install sheet noted as "They are not supplied"?
http://www.energysuspensionparts.com...sion/17359.pdf
I don't think you can from Honda. The camber arms on the top might be replaceable with aftermarket arms.
Old 04-17-2014
GM75's Avatar
i meant the three part bushing that's shown on the left and the upper arm but oem not poly's.
juror
Suspension DIY
07-30-2019 03:28 AM
brainwashedmc
07-27-2015 10:05 PM
muttleytm
07-14-2015 05:31 PM
fordover
07-11-2015 09:10 PM
muttleytm
07-11-2015 06:00 PM
Quick Reply: Rear trailing arm bushings
