Help:: Can rotating tires affect alignment??
Old Jun 21, 2003
zzzzzzzzzv's Avatar
zzzzzzzzzv is an unknown quantity at this point
Today I rotated my tires and was told to jack the car up first, then remove lugs. I tried doing that but I guess the lugs were all overtightened so I used a socket wrench to loosen them while the tires were in the air. My question is can my camber change by doing this (I have rear camber kits installed btw)? My other friend said that I should have loosened the lugs while the car was on the ground.
Right now.. it seems that my rear driver's side tire is more negative -0.65 --> ~ -1 and my rear passenger side is more positive -0.55 --> ~ -0.1 (tire hits fender now).
Old Jun 21, 2003
Vinh's Avatar
well....yes you shoulda loosen it when it wuz on the
ground
but the negative camber will be okay
and won't have that much of a dramatic effect
dun worry it will be alrite
Old Jun 21, 2003
zzzzzzzzzv's Avatar
heh yea.. i'm not worried about the negative camber.. but my right passenger rear tire became more postive so the tire hits the fender so the fender cuts into the tire.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
alaga
25
Aug 13, 2015 04:42 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
viperGTS
Jul 27, 2015 08:38 PM
