RSX rear 19mm sway bar installed
Old Jun 17, 2003
IronFist's Avatar
Thumbs up RSX rear 19mm sway bar installed
I bought one from a member of clubrsx. I received and installed it yesterday. There is definately a noticable difference in handling... the back end doesn't seem so sluggish during turns anymore. Understeer has been reduced.
I also installed a Neuspeed front upper strut bar a few weeks ago, and I have a generic rear upper strut bar coming from eBay. I'm excited
So, in conclusion, I give the 19mm RSX-S rear sway bar
Edit: I have a 2002 EX.
IronFist
Old Jun 17, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
slap some energy suspension or prothane urethane bushings on it and you'll REALLY notice a difference
Old Jun 18, 2003
IronFist's Avatar
What are prothane urethane bushings?
And energy suspension? Is that springs and shocks?
IronFist
Old Jun 18, 2003
Grey's Avatar
DIY King
Look here: DIY: Energy Suspension Sway Bar Bushings Also, I have some for sale here: FS: Energy Suspension Greasable Sway Bar Bushings
Old Jun 19, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
mmmm, urethane.
Old Jun 19, 2003
ohmysac's Avatar
thanks grey
Old Jun 19, 2003
IronFist's Avatar
And what exactly will these do for me?
IronFist
Old Jun 19, 2003
RedDragon333's Avatar
it will pull the rear of the chasis tight so you wont have any flex while turning and handling will be stiffer
Old Jun 20, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
I recently installed the type-s bar along with ES bushings and neuspeed front bushings. It made a big diff. I really love the handling of the car right now.
Old Jun 20, 2003
ohmysac's Avatar
i'm running the same setup...i think i have the handling about where i want it
Old Jun 22, 2003
18inchpride's Avatar
18inchpride is an unknown quantity at this point
I just put my Skunk 2 coils and a Rear sway bar from a RSX-S and i think that its the best upgrade i've done so far, the handeling is sooooo amazing now!!!!
Old Jun 23, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
No sense starting a new thread... got a few quickies now that my bar has finally arrived.
1. Do you have to grease the bushings when you install it (they're the Acura bushings)?
2. I don't think it'll happen, but do the lower arms come down when you pull the old bar off (do I need to prop the arms up)?
3. Is there a specified torque on the end link bolts?
Old Jun 23, 2003
Grey's Avatar
DIY King
1. If they're rubber you don't grease. If they're polyurethane you grease. I think the OEM ones are rubber.
2. Old bar? If you have a rear sway bar already and you detach it, nothing else will move. If you're talking about a rear tie bar, then yes. The lower control arms will move down. Not with force, but they'll slide out. Take off the wheels and use a jack from underneath to get them back into place. Some tweaking will be required of course...
3. Hmm... All bolts have a specific torque that they should be set at. Search Google.com and look up the torque spec. The torque spec. also varies with bolt size, number of threads, and bolt material.
Old Jun 24, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
how much r the energy suspension or prothane urethane bushings for the rear
Old Jun 24, 2003
Grey's Avatar
DIY King
Go to jegs.com and find out for yourself. They're $13.99, but some cost more. Shipping is another $5 or so. I think you can get them for cheaper somewhere else, but I don't know where exactly... ??? Anyway, I also have a 27mm front set for sale. The link is in my sig.
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
CapYoda
Nov 11, 2001 05:17 PM
