squeaking noise i don't think is my coil-over
Old Jun 17, 2003
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
Sup i just bring it to shop and reinstalled my rear coil-over. i don';t have that metal to metal sound no more.. good! my rear still making those squeaking noise i think is my rear camber kit? do your rear camber kit make those sqeaking noise? i got spc camber kit
Old Jun 17, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
the camber kit bushing was probably tightened before the car was on the ground. I had the same problem. you need lo loosen the bushing, lower the car, then tighten it really good. it's the bolt that attaches the camber kit to the rear drum.
Old Jun 19, 2003
Distinctive's Avatar
Smell My Face!!
true true......
Old Jun 21, 2003
orso's Avatar
orso is an unknown quantity at this point
mine does that too. i have the ingalls kit. i think the big reason it squeaks is that the bolt is moving up and down in the hole. if you look at the stock piece you will notice that the nut is welded to the arm, and the other kits come with the nuts seperate. i have tought about trying to weld the nut the arm. should do the trick.
Old Jun 21, 2003
Amplify's Avatar
Amplify is an unknown quantity at this point
Hmm... my rear camber kits squeak too. Gotta try that.
Old Jun 21, 2003
CivicHX01's Avatar
not really... the reason it squeaks is because the bushing is polyurethane (makes for a stiffer ride) and needs to be constantly lubricated, get some all-weather lubricant that won't wash off and slap it on there...
the stock arm has a rubber bushing which is not as stiff but does not ever need to be lubricated...
Old Jun 22, 2003
orso's Avatar
i have rubber bushings. and i don't think they are going to make noise.
Old Jul 10, 2003
Turbulent's Avatar
Turbulent is an unknown quantity at this point
I thought that the Ingalls come with the rubber bushings instead of urethane. Is this true?
Old Jul 11, 2003
orso's Avatar
ingalls makes both.
ghondavic
Transmission
Apr 12, 2017 09:37 PM
aZnVoYCe
Dec 7, 2001 12:41 AM
duyaknow
Nov 23, 2001 07:28 PM
LuvMyCivic
Nov 13, 2001 09:11 PM
aZnVoYCe
Nov 11, 2001 10:43 PM
