Coils or Springs
Old Jun 11, 2003
Phanibal's Avatar
Phanibal is an unknown quantity at this point
Question Coils or Springs
I am new to the lowering springs deal, but I was wondering if you guys could help me out. First of all whats better springs or coils. Next I heard if I get coils its a bumpy ride and that I also have to buy cambers. I see on ebay springs and coils for like 75 bucks. I am scared to buy them because that sounds too cheap. I would like to spend no more then 150 dollars, so what is my best bet on a good deal for lowering my car. Thanks for the help
Old Jun 11, 2003
armageddon's Avatar
armageddon is an unknown quantity at this point
You mean coil-overs??
Old Jun 11, 2003
Phanibal's Avatar
Yes coilovers, I am sorry for being so dumb just need some education on the subject
Old Jun 11, 2003
Weaponx12o's Avatar
if your limit is 150, you should get springs. neuspeed sport will give you a 1.75" drop and most likely you wont need a camber kit. the new goldlines will also give you a nice drop. eibach sportlines will give you a 1.4" drop. some of these springs might cost over 150, but you can always check out the group buy section on this site. dont buy those cheap no-name coilovers and springs from ebay!
Old Jun 11, 2003
Phanibal's Avatar
Thanks for the advice weaponx so, let me get this straight, if i get neuspeed springs I don't need to buy anything else, and also is the diy easy
Old Jun 11, 2003
Weaponx12o's Avatar
you still need to buy new shocks because your stock shocks will eventually blow. the only aftermarket shocks out right now are the koni yellows, but you can always wait for the tokicos to come out. the tokicos were supposed to be out already, but the release date kept getting pushed back.
Old Jun 11, 2003
VNlilMAN's Avatar
The Standard One
to clear thing up, you have HAVE to buy new shocks. its always recommended anytime you lower your car but you dont HAVE to.
and camber kits same thing... you dont HAVE to. but its recommended.
i didnt get new shocks or camber kit JUST neuspeed sports. www.aieonline.com has them for $145 shipped.
DO NOT buy ebay coilovers. if you do decide to go with sleeved coilovers stick to ground control or skunk2.
Old Jun 12, 2003
RoadRunner's Avatar
ebay is a no no. and if your gonna get coilovers, i suggest teins. Because you want true coilovers comparted to sleeved. Sleeved coilovers would be like skunk2. those will be bumpy as hell. you could just go with springs as well. do some research
Old Jun 12, 2003
Phanibal's Avatar
What is the difference between sleeved and non sleeved, p.s thanks for all of the advice so far fellas
Old Jun 12, 2003
Weaponx12o's Avatar
sleeved coilovers are just the adjustable springs itself, without shocks. you would still need to buy aftermarket shocks just like the springs. the best sleeved coilover companies are ground control and skunk2.
non-sleeved or true/full coilovers are a full replacement of the suspension. this means that it comes with adjustable springs, and shocks. its easier to install because you just take everything out and put the new ones in. the best full coilover companies are B+G and tein. i have B+G.
heres a pic of my drop, 2.25"
Old Jun 12, 2003
Phanibal's Avatar
damn weaponx that **** looks mad clean, not to dog your style but I want a drop like that, its perfect. Now that I know the difference I mine as well get true coilovers but if you don't mind about how much did you spend for the true coilovers from b and g? thanks
Old Jun 12, 2003
Weaponx12o's Avatar
you're going to have to save up. b+g's and teins cost from around 900-1200. i would have gone with teins, but they didnt drop low enough for me so i went with B+G's
Old Jun 12, 2003
Phanibal's Avatar
Oh wow never mind then, i'd rather spend that on rims, okay never mind that then, so after all of this helpful material I think the regular sport springs from neuspeed would work best. I probably don't need like vaniliman said any chamber or new shocks. thanks again everyone for the help........
Old Jun 12, 2003
Weaponx12o's Avatar
you do need new shocks.. eventually. because our stock shocks suck. you can get konis for around 500, maybe cheaper, or wait for the tokicos. just be careful when/if your shocks blow, because you will bottom out
Old Jun 12, 2003
Phanibal's Avatar
oh ****, so potentially if I don't get new shocks then, I will **** myself and the car will bottom out, well then maybe its just worth saving up for bgs so there is no hassle at all. hey vaniliman, has your car bottomed out or is it going to, better check that out according to weapon x
Old Jun 12, 2003
VNlilMAN's Avatar
The Standard One
"just be careful when/if your shocks blow, because you will bottom out"
not necessarily... it will be a bit more bouncier but that doesnt mean your going to bottom out. depending on how much gap and how much of the bumpstop you cut you wont bottom out even with blown shocks...
i had my neuspeed sports for over a year now. my stock shocks are still fine. the ride isnt as good as it used to be(mainly cause i have 18s now) but its still fine. yes you will eventually have to replace them but you should be fine for now.
Old Jun 13, 2003
Phanibal's Avatar
**** okay vanili thanks for the info
Old Jun 14, 2003
iceman's Avatar
--< GripSpeed Member >--
oh yeah..just to let ya know..so u dont end up wit the same dillema like me...if u do decide to buy springs...figure out whether or not ur gonna get a kit...if u are find some springs that will give u the right height..cuz wit me i wasnt thinkin..and i went wit progress which gave me about a 2.25 drop all the way around once it settled...and now that ive decided to buy a kit...my car will be too low once the kit is on(my driveway is steep and i cant park outside at night) and i have to resort to gettin coilovers
Old Jun 19, 2003
Phanibal's Avatar
So would you be willing to sell those springs once you get coilovers?
runawaykinms
15
Mar 22, 2019 10:32 AM
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
TheRiddicles
Sep 21, 2015 01:28 AM
RSKtakR
25
Sep 14, 2015 07:43 PM
