how long to install B+G???
Old Jun 10, 2003
ncwcivic's Avatar
ncwcivic is an unknown quantity at this point
I will be getting my B+G coilovers thursday and wanted to install them on friday. I will only have about 8 hours or less then i need to get alignment right away, right???
How long would it take to install, and as to above DO i need an alignment right away or will i be able to wait a couple days????
also i will be doing alot of driving over weekend, about 600+ miles
thanks
Old Jun 10, 2003
VNlilMAN's Avatar
The Standard One
8 hours should be plenty of time..
as for alignment. i normally recommend you wait a week or two. so that everything can settle and since you have coilovers, gives you time to adjust it to the height you like...
i guess even if you do drive 600+ miles i would just wait. 600 miles is alot but not enough to kill your tires. well unless if you have your car slammed 4" or so.. and your on stock tires still right? who cares.. i would just wait till you find the perfect height
Old Jun 10, 2003
civicvtec1ps's Avatar
Search and Learn
8 hours is plenty time to install full coilovers.you will be fine without getting alignment rightaway . i didnt get alignment for 2 months after i got my tein ss installed, it was fine..
Old Jun 10, 2003
ncwcivic's Avatar
i am actually on brand new falken ziex 512, on 18" rims
also should i do camber right away or wait till totally adjusted and set to where i want it for sure
i am looking at 2-3" drop
thanks for help so far
Old Jun 10, 2003
Distinctive's Avatar
Smell My Face!!
8 hours is plenty...for sure...and maybe you can get alignment done too
Old Jun 10, 2003
Search and Learn
just let it settle. give couple days then get alignment. you should be fine driving around for couple days.
159
Jul 5, 2015 09:54 PM
Schneiderman
May 24, 2015 01:14 PM
jackoncruzpr
May 24, 2015 12:24 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
SneakerPimp
Nov 5, 2001 10:49 PM
