Those with H&R's....
Old Jun 1, 2003
R1Style's Avatar
If I do the install myself, will I need a spring compressor or not?
Thanks
Old Jun 1, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
You need a spring compressor to install any springs.
Old Jun 1, 2003
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
what is spring compressor do?
Old Jun 1, 2003
RoadRunner's Avatar
you'll need a spring compressor regardless of what you get
Old Jun 1, 2003
R1Style's Avatar
Actually, a guy I know (CoupeStylz) just installed his Goldlines by himself and he didn't need a spring compressor.
I just wanna know if anyone has actually done this themselves because when I start... I don't wanna stop and go have to rent a spring compressor in the middle of everything.
Old Jun 1, 2003
666's Avatar
666
666 is an unknown quantity at this point
If you don't get a spring compressor make sure you have a friend of two hold onto the spring when you are taking the strut apart. There is alot of tension when you take the top nut off and it does make the installation of the spring easier with a spring compressor too.
Old Jun 1, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
play it safe, rent spring compressor, or you might get hit rignt in ur face, cuz tension~
Old Jun 2, 2003
R1Style's Avatar
True enough... I might just go rent one. Big and myself are gonna do the install together. We've got to put his Ground Controls in and then we'll do my H&R's.
Old Jun 7, 2003
Diablo's Avatar
Diablo is an unknown quantity at this point
you would need a spring compressor to remove the stock springs or you might strip the nut. but to install the H&R's i didnt use one they are smaller than the stock so i just pushed down wile my brother put the nut on it dont take to much force. ANy ways the safest way would be with a spring compressor
Old Jun 7, 2003
R1Style's Avatar
Thanks man.
Old Jun 9, 2003
nuffsed's Avatar
check out Mex's DIY on the site... he doesn't use a spring compressor... it shows you how he does it...
Mex's DIY
Old Jun 10, 2003
R1Style's Avatar
Yeah dude... I already checked it out. Awesome DIY.
hughheff
Mar 30, 2014 01:57 PM
awbooth
Jan 15, 2012 04:44 PM
hunterln
Wheels and Tires
Dec 4, 2009 02:11 PM
remmick69
May 15, 2009 05:10 PM
