Neuspeed strut bar installation question
Old May 29, 2003
IronFist's Avatar
Yeah I know it's supposed to be easy to install.
I just bought one (thanks civicvtec1ps ), but it's at home and I'm at college so I haven't even seen it yet. I didn't get instructions so I just want to make sure I know how to install it when I go hom.
Is it just like bolts off, bar on, bolts on and tightened to 33lb/ft?
Thanks,
IronFist
Old May 29, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Bolts off (not all of them, just the 2 on each side you need), put it on, if it won't fit, jack the front up just high enough that the wheels leave the ground, push it on, put it down, bolt it back in, 33 ft-lb and done.... thats basically what it says. If its an 02, then bend the clutch reservoir bracket forward a tad. if its an 01, you need to relocate it... not sure where though... www.neuspeed.com ... they now have most of the instruction sheets online.
Old May 29, 2003
bboyclumsy's Avatar
bboyclumsy is an unknown quantity at this point
I just installed mine like a half hour ago, same one i have 03 ex coupe, and didnt have to jack up at all. The tools u name are right. Also one side goes on easy other u have to wiggle alittle and use a small amount of force to get on. Took me 5 min to do though wasn't bad at all.
Old May 29, 2003
civicvtec1ps's Avatar
Search and Learn
yea just take out 2 bolts . put it on. torque 33!
i left feedback for you!
Old May 29, 2003
IronFist's Avatar
What do I click on to be able to leave you feedback?
IronFist
Old May 29, 2003
Search and Learn
IronFist
go click on my profile. and you will see. its right under my status
Old May 30, 2003
IronFist's Avatar
I left you feedback now. Thanks.
I installed the bar tonight. I had to jack up the driver's side, but it went on fairly easily with a little convincing.
Thanks for the part.
IronFist
Rogelio Rey
May 24, 2015 08:30 PM
PlatnumBomb
Bolt-on Engine Performance
Nov 9, 2001 01:11 PM
klectic
Nov 6, 2001 09:10 PM
andylao
Nov 4, 2001 01:19 PM
3rdcivic
Oct 24, 2001 12:19 PM
