Progress springs sagging?
Old May 28, 2003
Mags's Avatar
will you make out with me
Mags is an unknown quantity at this point
I have a set of Progress springs on my 03 ex and they sit about 1.5" lower in the back than in the front. I really don't like the way that looks. Plus it's jackin up my tires. Is this normal for progress springs, or did I just get a sh*tty set? Thanks guys.
-Keith
Old May 28, 2003
Mags's Avatar
Before you go flaming, yes I have a camber kit.
Old May 28, 2003
robbclark1's Avatar
Retired suspension supermod.
if you get a pair of shocks it should help. Progress springs are a little on the soft side so they bounce a little.
Can you give us any more information on the problem?
Old May 28, 2003
Mags's Avatar
I don't really have any good pics of the problem. My rear tires are tucked under the wheel wells, while the front ones have about 1/2 inch between them and the wheel wells.
Old May 28, 2003
Mags's Avatar
That picture was with the stock wheels (obviously) and it doesn't look as bad there. I now have 16" Maxxim 178's with 205/50 toyo proxes fz4 and it seems to be worse. I had a 02 civic ex last year with the same setup except enkei rs6 17's and I don't remember the back sagging this bad.
Old May 28, 2003
UpNorth2k1's Avatar
UpNorth2k1 is an unknown quantity at this point
I know a guy that has progress springs and yes the rear is tucked in... and ofcourse the front isnt or he wouldnt be able to turn. For sure the rear was lower, but not significantly... so i dont know about 1.5"?? It looked good though, the car didnt look lopsided. Btw this guy has had his car for much more than a year with these springs and stock shocks. They are still not blown.
Old May 28, 2003
VNlilMAN's Avatar
The Standard One
thats just the way progress are.. thats why i didnt get them. this one vic that drives around has progress. the front has a little gap and the rear tucks alot.. doesnt look pretty..
ya if you get konis, you can fix the problem by setting the rear perch to the top one. but then again cheaper fix is just getting new springs
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
