torqueing down the rear sway bar
Hey
I bought the progress 22mm rear sway bar for my 2002 civic and I was wondering how much you guys torgue the bolts on the sway bar bushings
DIY King
Originally posted by ak
33lbs i think...baa
it will hold.
33lbs i think...baa
it will hold.
Grade 5 bolts come with the Progress rear sway bar. For that size, 33 foot pounds is about right. I upgraded to Grade 8 bolts and I torqued them down to 46 foot pounds.
If you don't torque them down enough then they will vibrate loose after a while. I found out the hard way, so torque them down to spec. Also, you might want to mark the bolt and the holder with a line across them to mark the position of the bolt. That way you can check to see if it loosened. If it did, then it's too loose! Re-tighten it. I did this as well.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
breanna_17
Jul 21, 2015 04:01 PM
fordover
Jul 11, 2015 09:10 PM
