Allen socket stripped - Help!
Old May 3, 2003
Aziego's Avatar
Aziego is an unknown quantity at this point
Murhpy's law striked again! I was trying to swap the rear swaybar of my civic when the darb allen socket of the passenger side stripped. I was able to take out the end link bolt of the driver side pretty quick but the passenger side was a little stubborn. After working the bolt about 3/4 of the way out the darn socket stripped on me. There is not even enough grip to tighten back the bolt.
What should I do? How do I best fix this? I am thinking of replacing the entire end link, that is if the other side holding it to the rear suspension frame don't strip too.
Is my car safe to drive with the sway bar hanging loose on the passenger side. I figure the performance might suffer.
Old May 3, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
If you can get a big enough easy out (stripped screw removal tool), you can probably get the bolt out... then just replace it. I wouldn't drive with the sway bar loose.
Old May 3, 2003
VNlilMAN's Avatar
The Standard One
maybe vice grips would work? usually it'll get the job done.
Old May 3, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Lightbulb
If you have a dremel tool w/ a cutoff wheel, you can grind a slot in the allen head. THen just use a screwdriver.
Old May 4, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
were you using metric tools? very important that you always use metric when working on your civic
Old May 4, 2003
Aziego's Avatar
I am going to dremel a slot in the head so that I can at least tighten back the nut. I was using a metric allen key.
h4ldol
Apr 24, 2017 08:16 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
meicalnissyen
Sep 25, 2015 12:12 AM
Styven Szastur
Sep 23, 2015 05:26 PM
Bruce2
Sep 21, 2015 08:01 PM
