Spring Rates
Old Apr 25, 2003
robbclark1's Avatar
Retired suspension supermod.
Spring Rates
Is there a way to tell what the spring rates are on lowering springs/coilovers. Most manufacturers don't mention it on their site. I know JIC can have custom spring rates or even ones that you can change the spring rate yourself. Thanks.
Old Apr 25, 2003
Zzyzx's Avatar
Autocross Junky
you can have them tested. Problem is, I dont know where. Many co's dont list spring rates because the average person who Purchases Sport/Lowering springs wouldn't know what do do with the Information. The more Reputible Racing suspension companys like H&R, Tein, Eibac, and Neuspeed to name a couple, would be more then happy to tell you the their spring rates, all you have to do is call them and ask.
Old Apr 25, 2003
Wanger's Avatar
Wanger is an unknown quantity at this point
Tein S Tech spring rate:
front/back:
2.8/5.2
Old Apr 25, 2003
Zzyzx's Avatar
Autocross Junky
front/back:
2.8/5.2
We under stand LBS/In her in America. Metric tends to confuse us.
157lbs/in front and 291lbs/in on the back. not very stiff at all.
The SS springs are
336lbs/in front and 448 lbs/in back. More then twice as stiff on the front.
Old Apr 25, 2003
VNlilMAN's Avatar
The Standard One
and its also hard to say with progressive springs since it varies... it gets stiffer n stiffer as it gets compressed more..
Old Apr 1, 2004
RedEU's Avatar
RedEU is an unknown quantity at this point
so, the tein rate is linear or progressive?? & is the ss really doubling the stiffness??
Old Apr 1, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Coilovers are linear racing springs, lowering springs are typically progressive.
Old Apr 1, 2004
Zzyzx's Avatar
Autocross Junky
when Racing is involved Linear springs are better to have then Progressive ones. on the street, Progressive will give you a better ride when your just cruzin but still retain some level of performance when pushed.
Old Apr 1, 2004
robbclark1's Avatar
That is why companies like eibach, progress, neuspeed, etc say it is x-x% stiffer than stock. They vary when they are compressed/extended.
Old Apr 1, 2004
Logan3024's Avatar
The SS springs are
Conversion Chart. Should be useful for some people.
0 Kg/mm 0 Lb/In
1 Kg/mm 56 Lb/In
2 Kg/mm 111.9 Lb/In
3 Kg/mm 167.9 Lb/In
4 Kg/mm 223.8 Lb/In
5 Kg/mm 279.8 Lb/In
6 Kg/mm 335.7 Lb/In
7 Kg/mm 391.7 Lb/In
8 Kg/mm 447.6 Lb/In
9 Kg/mm 503.6 Lb/In
10 Kg/mm 559.5 Lb/In
11 Kg/mm 615.4 Lb/In
12 Kg/mm 671.4 Lb/In
13 Kg/mm 727.4 Lb/In
14 Kg/mm 783.4 Lb/In
15 Kg/mm 839.2 Lb/In
16 Kg/mm 895.2 Lb/In
17 Kg/mm 951.2 Lb/In
18 Kg/mm 1007.1 Lb/In
19 Kg/mm 1063.2 Lb/In
20 Kg/mm 1119 Lb/In
Old Apr 1, 2004
robbclark1's Avatar
Boilermaker1 gave this awhile ago.
1 lb/in=.017854 kg/mm
Old Apr 1, 2004
Zzyzx's Avatar
Autocross Junky
One of my friends estimated the rate of his springs by measuing the Diamiter of the coil, Simmilar to how you can calculate the rate of an anti-roll bar by knowing its thickness.
I'll ask him about it.
Old Apr 1, 2004
Zzyzx's Avatar
Autocross Junky
Found a Coil spring rate Calculator...
Another (More Informative)
Old Apr 2, 2004
Unleaded's Avatar
Unleaded is an unknown quantity at this point
neuspeed race springs are 285/400. since they are performance minded springs, are they still progressive like the sports springs?
Old Apr 2, 2004
flotsamm's Avatar
You can tell its a progressive spring if it has dead coils on it. Whereas a linear spring coils are evenly spaced for the most part.
Old Apr 2, 2004
robbclark1's Avatar
most true coilovers are linear springs, most aftermarket springs are progressive. Sleeves are just aftermarket springs on an adjuster so they are usually progressive too. But flotsamm is right.
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
