When Cornering I Jiggle...
Old Apr 15, 2003
Grey's Avatar
DIY King
I tried to make up a funny title. LOL Anyway, when cornering hard my steering jiggles and the front tires seem to wobble around. I'm not sure if this is some new problem, or if this is just something I'm encountering now since I've been pushing my car more and more? In my mind it seems like the little shocks on the tie rods are messed up. We do have little shocks for taking care of bump steer, right?
Bleh. So many unknowns! I don't know what this is and I don't know how to fix it? Maybe it's something everyone has? If so, then would a X-brace solve this problem? Certain people say it's better when going over bumper (jwsisme for example). I think I notice this problem of mine when cornering over little bumps, but I'm not sure?
Here's my suspension setup:
1. Front and Rear Progress Sway Bars (27mm front, 22mm rear) /w polyurethane bushings.
2. Front and Rear Spoon Sports strut tower bars.
3. 17x7.5 45 offset Rota Attacks /w 215/45 Kumho Ecsta Supra 712's
Old Apr 15, 2003
HondaLuver's Avatar
Its a celebration bitches!
humm, i think you probly need to get a computerized alignment...
Old Apr 15, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
Same problem here. My rear end "wobbles" when I go over manholes or hit potholes. I think it has to do with shocks since when I replaced my Konis my rear doesn't do it as much
Old Apr 15, 2003
Grey's Avatar
DIY King
Oh yeah, my front shocks are worn more than my rear ones. That's for certain. Hmm...
Old Apr 15, 2003
Zzyzx's Avatar
Autocross Junky
Umm... what kind of tire rollover are you getting? you could be over driving the tires, when you do that they can actually "skipp" durring hard cornering. It Kinda sounds/feels like those rumble strips on the sides of highways. If you are just back off a little, or get higher performance tires, like some compitition radials(Kumho Victoracers)
Old Apr 15, 2003
Zzyzx's Avatar
Autocross Junky
Oh ya, What tire pressure are you running Front to rear?
Old Apr 15, 2003
Zzyzx's Avatar
Autocross Junky
Just to clarify, Bump steer it Basically toe change due to suspension compression. It will feel like the car Is pulling in a different direction then where the steering wheel is pointed. Ushually its only encountered on Dips and the bottom of fast drops (when your suspension compresses). though it can happen when the suspension Uncompresses past normal suspension travle.
Old Apr 16, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Question Bump Steer?
OH! That is what I have noticed recently. I just got my springs repleced because my ride was not low enough and every so often when I am cornering and I go around turns, even when I am coming to a stop and there are bumps or dips in teh road my steering wheel seems to want to turn slightly. I thought that my steering was going to fall apart. Of course I may ned an alignment myself since I have not gotten one since I got the suspension replaced.
So does it matter how low you are to the ground as how dramatic the bump steer is?
Just wondering.
Old Apr 16, 2003
Zzyzx's Avatar
Autocross Junky
Yup, the lower you go the more prevailent Bump steer will be. Honda claims that the reason Our suspension has an abnormal Strut, is to reduce BUmp steer. but who knows.
Old Apr 16, 2003
eXNBP's Avatar
Re: Bump Steer?
Just wondering.
Might also be your tire gripping a bit better with a wider tire. Are you running on stock tires?
Old Apr 16, 2003
Grey's Avatar
DIY King
Zzyzx: I'm not sure what kind of tire rollover I'm getting? I don't know what that term means? I'm running 33psi up front and 31psi in back. I have a digital tire pressure gauge with a %1 accuracy.
I did check my front struts out a while back and they're more worn than the rear. I push down on a corner and it bounces once before it recovers. The rear simply goes up when I let go and it gets damped quickly. Might that have something to do with it?
Old Apr 16, 2003
jwsisme's Avatar
jwsisme is an unknown quantity at this point
I think it would have something to do with it, yes.
The xbrace didn't seem to help the steering feel, as much as it helped the front wheels from flopping around. Before the xbrace, the wheels didn't really care if they were on the ground, with the xbrace the wheels really tried to stay on course and on the ground, similiar to a LSD.
So.. I think you would really appreciate the xbrace, but I dunno if it will completely fix your issue, cause it might be something else...like new struts.
Old Apr 16, 2003
Zzyzx's Avatar
Autocross Junky
Tire roll over is the mesure of how much the tire is bending durring cornering. You mesure it by putting Tick marks on your tires with some window chalk and driving. Where the Chalk gets rubbed off will tell you how much your tire is rolling over.
you can just bairly make them out on my car.
Just mark from whithin the tread to about 1/2 inch down the side wall, in about 3 - 4 places.
I do it when I autocross so I can adjust tire pressure. you want the tire to roll just a bit. Ushually there is a little arrow/triangle on the side wall near the tread, you dont want the tire to wear past that. on the street I run 32 up front and 30 on the back, when I autocross, 44 up front 32 on the back. (205/40ZR17)
If the Strut allows the spring to bounce more then once after a bump then its blown, or is to weak for the spring. (Push down on the car, It should bounce up then settle.)
Oh ya, after a little thinking I Figured out that by placeing the Steering rack High(and screwing Strut MFG world wide) Honda Did not really get rid of Bump steer they just changed what it did. When a car with the steering rack mounted low experience Bump steer, the action will cause Toe out to occur. this causes the car to pretty much do what it wants. With the Steering rack mounted High, Bump steer causes Toe in, makeing the car want to go strait. to counter this, if you happen to experience this often just align the car with a little more Static Toe out.
Old Apr 17, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
im having that problem now to since i lowered my car, but it wasnt as apparent before, but now its pretty bad, its most likely the shocks are done...
Old Apr 17, 2003
Sivion's Avatar
Resident Tough Guy
Tires
No, I am running 205/40/17 front and rear. Kumho on rear and I forget what is on the front since I am sitting at comp and it's not coming to mind for some reason
Old Apr 17, 2003
Grey's Avatar
DIY King
What did you lower with? I didn't even lower the car, but I think that this is the problem. Hell, I think I'll take it to Honda and see what happens.
Old Apr 23, 2003
WannaBFast's Avatar
well i would have to switch the springs back to stock and bring it in...
i used the neuspeed sport springs... and they wont touch it cause it lowerd... i mean its drivable, so i dont see the point in going thru all that work just to get free shocks... cause i would have to switch them to stock, then switch them back once i get the new stuff... might as well wait for koni's
Old May 13, 2003
Grey's Avatar
DIY King
Problem solved! I replaced the front shocks with new ones from a friend (thanks noname!) and now my front end is solid when I corner.
dlg1985
Jul 23, 2017 10:03 PM
Whitexj
Sep 30, 2015 02:04 AM
Sep 27, 2015 11:33 AM
