I rub!!!
Old Apr 15, 2003
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
I rub!!!
I just got my Neuspeed Sports and SPC rear camber kit installed yesterday. I have Velox VX-8 rims (17x7.5) and Toyo 215/45/17 tires. The drop looks great... its not too low, but it is nowhere near stock! But as many of you probably experience... on hard or sharp turns, there is some rubbing. Its not too bad, but it does exist.
I just wanted to post, because I often searched this topic and I see people ask the same question over and over again. I didn't come across anyone with this exact wheel/tire/spring setup, so it may help someone.
And finally, yes the Neuspeeds are noisy. They are still settling though, so we'll see. Later I will put in coil seperators to see if it helps.
Old Apr 15, 2003
Spider883's Avatar
9K Redline Owns U
u need to set the camber right so when the wheel goes up in the wheel well they will not hit the fender lip
Old Apr 15, 2003
Deejai35's Avatar
Is the OEM spec on camber negative or positive? When I got an alignment yesterday, they said the front was off. I don't remember exactly how much, but it was the opposite of the manufacturer spec. Neg to pos... or vice versa.
Old Apr 15, 2003
robbclark1's Avatar
Retired suspension supermod.
OEM spec should be slightly negative if not zero. But I am not quite sure on that.
Old Apr 15, 2003
Spider883's Avatar
9K Redline Owns U
i have my front at -.1 and my rear at -.3... i can do that on my rear bc i dont have a rear fenderlip anymore
Old Apr 15, 2003
Deejai35's Avatar
I think I need the front camber kit... I am like +.1 I think.
Old Apr 15, 2003
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
tires are too big man...get some 35's or 40's but that's as high as i'd go. i have 18's and 35's with neuspeed race springs and no rub.
Old Apr 15, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
I have 205/50/15 tires with a Neuspeed race and only rub on hard or slow turns.
Old Apr 15, 2003
Deejai35's Avatar
Do you experience the clicking or popping sound with your Neuspeed Race? I only rub on sharp turns too, but you have 15s, so I see your point...
Old Apr 15, 2003
blouisgod's Avatar
Life Begins > 6800rpms
i have 215/45/17s with rims with a 42 offset so im probably going to encounter the same problem. whats the drop on the race springs? and would a prokit or sport springs work better?
Old Apr 15, 2003
eXNBP's Avatar
It pops once in a while I'm sure but I always have my stock system up all the way
Old Apr 16, 2003
Deejai35's Avatar
I was curious today, so I took a right turn really hard to see what would happen. The result, the fender lip (rear) practically sliced into the tread of my tires, not deep though.
So I tried to roll my fender lips today. I used the bat and rag method. But I don't have a full sized bat, and I didn't want to jack my car up in the air. So the mini bat worked fine for this job.
Now the fender lip doesn't cut into the tires, but it still rubs... its okay I am getting used to it.
I agree with eXNBP... I just crank the factory stereo up more...
UltraHDGames
Jun 8, 2016 05:16 PM
cukaracha
Aug 29, 2015 05:27 PM
Pudnite
May 9, 2015 07:51 PM
2Hottie
Detailing
21
Jun 18, 2002 09:39 AM
soljahboy17
Apr 1, 2002 03:24 PM
