cutting coils?
Old Apr 14, 2003
iamboo's Avatar
Retired - SoCal FI Mod
Question cutting coils?
i have first gen goldline springs that drop my car about 1.75"....
i really wanna drop it maybe by another half inch to and inch. one of my good buddies told me that i should just cut about half a coil on my springs and that if i do, it wouldn't affect ride quality all that much...
should i do it cause i have 17's on and it still have quite a bit of wheel gap?
Old Apr 14, 2003
BlueBoyCivic's Avatar
"Stage7"
My opinion bro..."don't cut it"
Old Apr 14, 2003
Zzyzx's Avatar
Autocross Junky
Bad bad bad bad bad!!!!!!
Cutting the spring comprimises their spring rate. Giving you Krap for ride quality. Dont do it.
Old Apr 14, 2003
robbclark1's Avatar
Retired suspension supermod.
Yeah what they say!
No one is stopping you and it will lower you car, but it will be a crappy ride
Old Apr 14, 2003
VNlilMAN's Avatar
The Standard One
CUT IT!!!
there is no effect on spring rate if you cut a DEAD COIL. this is coils that touch together. and i dont know about cutting just half, i would say cut the whole coil.
this is assuming goldlines have dead coils of course
Old Apr 14, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
1 full coil is better than 1/2. Good luck cutting it with a dremel or some sort of tool
Old Apr 14, 2003
flotsamm's Avatar
If you cut the coils I heard your not suppose to expose it to any heat during the cutting process, or as little heat as possible. Use a die cutter or some other low heat method.
runawaykinms
15
Mar 22, 2019 10:32 AM
h4ldol
Apr 24, 2017 08:16 PM
General DIY
Sep 25, 2015 08:02 PM
Mc7602
Sep 17, 2015 02:01 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
