Will I rub with a 2 in. drop on 215/35/18
Old Apr 13, 2003
LITTLELOUIE's Avatar
LITTLELOUIE is an unknown quantity at this point
Whats up guys I'm new to the forum and this is my first post, so Im getting my car lowered this week with the sprint 2" drop all around and sprint camber kit, will I rub with 18" wheels on 215/35/18 tires?
Old Apr 14, 2003
Frank2sy's Avatar
Frank2sy is an unknown quantity at this point
You won't rub when turning, but you rear tires will probably rub against the rear fenders when going over bumps. If your camber is adjusted to spec., your rear tires will rub against the rear fenders, because our rear tire well is not wide enough to hold 215 series tire.
Old Apr 14, 2003
DizWikedCivic's Avatar
front no u wont rubbed, the rear might rubbed depending on the camber
Old Apr 14, 2003
VNlilMAN's Avatar
The Standard One
nope. if they do, roll fenders, adjust camber.
Old Apr 14, 2003
Spider883's Avatar
9K Redline Owns U
no they wont.. im dropped all the way on coilovers, with a cut rear fender lip and oe specs on camber
Old Apr 14, 2003
mig's Avatar
mig
mig is an unknown quantity at this point
Spider883 - what did you cut your fender lip with, and how did you take care of the exposed metal after cutting it. also, how rigid is the lip of you rear wheel wells? How well would the lip resist say a door ding? thanks.
Old Apr 16, 2003
Spider883's Avatar
9K Redline Owns U
i cut it with a cutting tool and a grinder.. both air powered.. then i primed and painted the area.. and if a door hit it.. there would be a nice ding in it.. have to be careful... i own a shop so i have all of the stuff to do this
Old Apr 17, 2003
jaaaapp's Avatar
jaaaapp is an unknown quantity at this point
hey you're from daytona beach!! i used to go there (embry riddle). I moved over to cali now though.. that place's spring break's rockin!. i have the same f---iin problem with my new rim's + drop. the rear right tire hits the right rear fenders n don't know what to do about it.. what kinda cutting tool did u use? any other methods of going about cutting the fender off? I have 215/35/18 tires n a goldline spring. thanks.
Old Apr 17, 2003
VNlilMAN's Avatar
The Standard One
whussup jaaaap, sorry i forgot your name. you can always use a baseball bat. you have a camber kit huh? you can always adjust it and make it a little more negative as well..
Old Apr 17, 2003
Got my car lowered today and the rear gap looked fine at first but a couple hours they started to settle and in the rear I can only stick one finger I'm going to hit the rear fender when going over bumps.
Old Apr 17, 2003
get a camber kit, and make your camber slightly negative
Old Apr 17, 2003
slam2k1civic's Avatar
slam2k1civic is an unknown quantity at this point
no
Old Apr 18, 2003
jaaaapp's Avatar
should i make a lil cut so it'll fold more easily?? maaan, the ride back from frisco was messed up... can't count the number of cracks my right rear fender made. some ghetto ****. need to fix....
Old Apr 18, 2003
VNlilMAN's Avatar
The Standard One
naw, i wouldnt cut it.. just fold it. you know how to do it right? stick the bat between the fender and push it down.
if you want i can do it for you on sunday. imma be at alex's house. i think your koo with him right, maybe ask if you can come over too?
LITTLELOUIE, yup thats why i dont like sprint, the rear is lower then the front. i heard they corrected it. AK, alex has the new "corrected" ones. maybe try calling them to get it replaced? should have gone with neuspeed
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
Tedverseti
Sep 29, 2015 05:41 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
TheRiddicles
Sep 21, 2015 01:28 AM
