will thsi work???
Old Apr 13, 2003
nguyen949's Avatar
nguyen949 is an unknown quantity at this point
will thsi work???
i just bought goldlines with a 1.75 drop..and was wondering if i got my car alignment and tried to perfect the tilt as mjuch as i can without gettn a camber kit would that work? if so how long would my tires last
Old Apr 13, 2003
RoadRunner's Avatar
just do it the right way and get a rear camber kit
Old Apr 13, 2003
DizWikedCivic's Avatar
Re: will thsi work???
it depend how bad your camber is, 1.75 drop is not that bad, probably like 1-2 degree camber
Old Apr 13, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
with a 1.75" drop you should only need a rear camber kit. A wheel alignment you should have professionally done, but camber, if you have very good eyes, you could try to adjust it yourself. we're talking maybe $100 max for alignment/camber adjustment (with everything installed).
Old Apr 13, 2003
you can install your camber kit in yourself, and eyeball it, to have it correctly align u will need to get a shop to do it
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
