ground-control coilovers?
Old Mar 28, 2003
Ant81's Avatar
Ant81 is an unknown quantity at this point
i just installed my ground-control coilovers on my stock shocks and im happy, but i wanted to know what is the stock ride height from the floor on a 2002 Civic Si Coupe? Also my front looks good can fit about 2 fingers but my back like not even one finger fits ? is it bad and also i noticed that my back tires are slanted ? Thank you
Old Mar 28, 2003
noname's Avatar
Reppin' "Custom Concepts"
noname is an unknown quantity at this point
I believe
a camber kit should fix that problem
Old Mar 30, 2003
VNlilMAN's Avatar
The Standard One
you have coilovers, you can adjust the height, not happy with the rear, just raise it up..
n yes anytime you lower the car the tires are going to be slanted. thats why you get a camber kit and you get an alignment. driving with the tires slanted will cause your tires to wear out unevenly causing you to replace your tires sooner then you should be replacing them
Old Mar 31, 2003
Ant81's Avatar
ok i raised it 1 inch, but the next day i measured it again and it lowered by itself by half an inch what could be wrong and i checked the nut and it's not loose everything is fine? is it my stock shock?
Old Mar 31, 2003
djmota's Avatar
the springs and the upper spring cushion are settling. Its normal adjust it up more in the rear. It will stop pretty soon and be normal.
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
EM_WON
Jul 22, 2015 06:49 PM
