For Gold Lines.. do you need to cut the bump stop?
Old Mar 22, 2003
Toca's Avatar
Toca is an unknown quantity at this point
Old Mar 22, 2003
Elite's Avatar
Elite is an unknown quantity at this point
I think whenever you lower your car you need to cut your bumpstop. But im not sure on this would someone enlighten me thanks.
Old Mar 22, 2003
flotsamm's Avatar
Goldline recommends it.. check out this link on their page: installation tips
Old Mar 23, 2003
SilverStreakEX's Avatar
Show me your titties, I'M RICK JAMES BITCH!!!
SilverStreakEX is an unknown quantity at this point
direct quote from goldline: "The front bumpstop is optional but, we do recommend trimming the rear b/s."
go to last post from goldline
Old Mar 23, 2003
slystad810's Avatar
I trimmed the rear but the front is still intact. Rides fine although I just finished an hour and 1/2 ago.
Rides like stock! Getting the camber exactly right is a pain in the *** though.
Old Mar 23, 2003
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
i didn't cut mine and it rides fine. since july.
Old Mar 23, 2003
u have goldlines pete?
Old Mar 23, 2003
Taffy's Avatar
yep
Old Mar 24, 2003
really? cool, i just got them like a couple weeks ago, still tryin to find somewhere to install them. i got the newly designed coupe springs. which ones do u have?
Old Mar 24, 2003
Frank2sy's Avatar
Frank2sy is an unknown quantity at this point
I trimmed the rear bump stops when I installed Goldline springs with stock shocks. When I replaced the stock shocks with Koni's, I had to purchase new rear bump stops from the dealer. If I were to install Goldline with stock shocks again, I probably wouldn't cut the bump stops.
Old Mar 24, 2003
slystad810's Avatar
I have the redesigned coupe springs. Drop looks even all the way around. Rides like stock.
Frank how much did those bump stops cost you?
Old Mar 24, 2003
Taffy's Avatar
I guess i have the old design because i got them about a year ago... i guess thats why my left driver rear is lower than the rest..
Old Mar 24, 2003
lol, u know u can send them (the old ones) back to goldline, and they'll send u the newly designed ones right?
Old Mar 24, 2003
Frank2sy's Avatar
2 rear bump stops cost me $25.00 at the dealer. I think it's a rip off for 2 pieces of rubber.
Old Mar 25, 2003
WOW!! sorry u got raped dude, they got em here for $6.80 each.
Old Mar 25, 2003
Frank2sy's Avatar
I ordered some brake shims and a fog light switch from Majestic Honda today. They charge $4.95 Handling fee PLUS shipping . I guess that's how they make their profit.
Old Mar 28, 2003
brents1's Avatar
brents1 is an unknown quantity at this point
My rear springs did not have bump stops when I replaced them w/ goldlines. Were they supposed to be on the stock springs? Should I buy some and put them on?
I was wondering, if that's what is causing the noise from the rear. ????
Old Mar 28, 2003
Frank2sy's Avatar
Are you sure you don't have bump stops? They are essential to keep struts from bottoming out. I would highly recommend getting them and putting them on. If you are still running on factory struts, they are probably blown by now.
I have an EX model, and I have bump stops all 4 corners. I'm not sure about other Civic model though. I'm pretty sure they should have bump stops.
Old Mar 28, 2003
brents1's Avatar
maybe I'm thinking of something else. In the front I had a rubber/plastic tube that went around the bottom of the coil. Is that not the bumpstop? What does the bumpstop look like?
Old Mar 28, 2003
flotsamm's Avatar
I think your describing the spring isolators. Those are used to quite the dead coils from making noise when they touch each other. The bumpstops in the front are intergrated into the dust covers. The rears arent. Both go over the strut piston and sit at the top of each assembly.
Old Mar 28, 2003
slystad810's Avatar
On the rear they are made of yellow rubber/plastic (urethane?), and they have 4 segments. I cut the bottom two off.
It kinda looks like this ()()()()
Old Mar 29, 2003
cdmx's Avatar
I didn't cut either of my bump stops, the ride is fine???
If you think about it, not cutting the bump stops should cause the shocks to last "longer"
1028CiViC
Mar 21, 2002 11:29 AM
