exhaust in a way of sway bar
Old Mar 18, 2003
Erichyung's Avatar
Erichyung is an unknown quantity at this point
i read from another thread that 22mm aftermarket sway bar will get in the way of exhaust systems, such as tcs. Do you guys know anything about this? I'm not sure if this is true.
Old Mar 18, 2003
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
yes, even some of the 19mm type-s sway does that too, i have that problem. i put some rubber around the sway to prevent the knocking sound
Old Mar 18, 2003
rino's Avatar
rino is an unknown quantity at this point
is there any aftermarket exhaust that clears the progress 22mm sway bar?
Old Mar 18, 2003
robbclark1's Avatar
Retired suspension supermod.
Custom exhaust will. I am not sure about the greddy. There aren't many full cat backs, but i think that even Axle backs might get in the way. It is darn frustrating. that is why Grey is putting his bars on first, then getting a custom catback.
Old Mar 18, 2003
Spider883's Avatar
9K Redline Owns U
yea my 19mm bar hits my custom cat back every once in a while
Old Mar 18, 2003
EternalBluePearl's Avatar
EternalBluePearl is an unknown quantity at this point
dats f**k up
i have a magnaflow and im planing to upgrade my suspension
Old Mar 18, 2003
Grey's Avatar
DIY King
Yep, right on. I have both the front and the rear sway bars installed, so now I can gather up all of the exhaust components and weld myself together something that will clear everything. Hmm... Now that I think about it maybe I should lower the car first? Well, I'll be sure to design everything so that the exhaust has adequate clearance even if the car is lowered.
Old Mar 18, 2003
Friedrice's Avatar
Friedrice is an unknown quantity at this point
My HKS Hi-Power rear section has plenty of clearance with my 19mm RSX bar.
Old Mar 19, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
the magnaflow catback and rsx sway work fine. with the car at stock height, i have around 2 inches of clearance. so i'm assuming that once i lower the car, i'll still have adequate clearance between the two.
Old Mar 19, 2003
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
anybody have a greddy evo on their 2k1 coupe with a 19mm type s lower sway bar. I just picked one up and wanna make sure they don't hit or rub.
jdh022764
18
Nov 3, 2015 06:44 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
Viczhou
Sep 2, 2015 07:55 PM
