I need some info on coilovers??
Old Mar 14, 2003
BIGGIE's Avatar
BIGGIE is an unknown quantity at this point
Whats the best kind of coilovers to get? thanks cale from ohio
email sweet_civic@hotmail.com
Old Mar 14, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
The two main coilovers that are availible are Skunk 2 and Ground Control.... I personally bought Ground Control because they come with Eibach springs.... There are a couple of other off brands that I have seen but heard the ride is alot rougher with those....
Old Mar 14, 2003
XxJDMCivicxX's Avatar
Tein SS
Old Mar 17, 2003
Weaponx12o's Avatar
tein ss's are good, but they dont drop low enough for me, so i bought B+G's!
Old Mar 17, 2003
civicvtec1ps's Avatar
Search and Learn
Originally posted by XxJDMCivicxX
Tein SS
YES i feel u on that one.
i have tein ss. love the ride!!
Old Mar 17, 2003
VRoomPSHeRt's Avatar
VRoomPSHeRt is an unknown quantity at this point
id go with ground control... theyre good for the money!
Old Mar 17, 2003
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
Ground control are ok..... but true coilovers are alot better.... also
they are a better ride than shock and coil combo.....
Old Mar 17, 2003
CheeseFrog's Avatar
CheeseFrog is an unknown quantity at this point
Tein SS's are a good street coilover system, but they're not well suited to the track. The spring rate is just too soft. You can crank up the dampening all the way stiff, but then the spring rate doesn't match the dampening at that point and you could end up jacking the car down after a while. You could upgrade to some stiffer springs like 12kg/8kg but then that might be too much spring even at full dampening. But for the street and spirited street driving, the SS is pretty good.
I'd recommend something along the lines of JIC FLTA2's, Zeal B6 or S6, Tein RS, or Buddy Club Racing Spec. Granted, they are more expensive than the Tein SS's (about twice as much), but they're WELL worth it. I run Buddy Clubs on my '98 hatch and it handles extremely well. Load up the chassis in a turn and it'll just take bumps and expansion slots without upsetting the chassis balance at all. Real nice. My Civic handles better than my '93 RX-7 R1 did...
Old Mar 17, 2003
RedDragon333's Avatar
Well for cost reasons i would recomend Tein SS if you want true coilovers, if your looking for sleeves then go with Ground Control. If money is no bject then JIC is a good way to go look into investing about 1600.00 to 2000.00 for that setup. I look at it this way tho, if you want coilover sleeves (ground control, skunk) you have the the sleeves and then the purchase of shocks and your already close to the cost of Tein SS so save up a bit and do it all at once with the TeinSS
Old Mar 17, 2003
Distinctive's Avatar
Smell My Face!!
i think ground control and skunk2 are the best besides true coil
overs...dropzones are my 2nd choice...i had on my other car 90
integra.. and they were like a factory ride lowered 2and half inches.
later
n8
SoslowEj666
Mar 8, 2016 01:10 AM
JKWood
Jul 28, 2015 03:45 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
