Neuspeed Spring Owners!
Old Mar 3, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
Hey everyone, need some info here. I just picked up a set of Neuspeed Sports and was wondering if they came with the spring isolators? And does anyone know where I could find some for my install?
Thanks!
Old Mar 4, 2003
SedanBoy's Avatar
help? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 4, 2003
Nuts's Avatar
Nuts is an unknown quantity at this point
nope they don't come with those. the only thing that comes in the box are the springs. i just finsished installing the front neuspeed sports and its not hard at all. just get a good rachet set and spring compressors. oh and when you come across the tie rod where you have to pop it out, you don't need to rent anything, just put a nut at the bottom of the screw and hammer it up.
Old Mar 4, 2003
SedanBoy's Avatar
cool. thanks!
if i don't use spring isolators when installing them, will there be the creaking sounds that ppl complain about?
thanks again!
Old Mar 4, 2003
Nuts's Avatar
i have about 50 miles on the car with the front lowered and i hear no creaks. i didn't use spring isolators. i won't be driving my car tho until it stops raining so i can thow on hte rear springs. its gonna usually creak anyways until they settle in a week or two.
Old Mar 4, 2003
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
I don't know what a spring isolator is, but I think ya'll are talking about a little rubber tube you put over the spring? I have Neuspeed Sport and even after it settled, it still squeeks due to the dead coils stacked on top of eachother, and the fact that I put the fronts in upside down (Neuspeed said that there was no harm), don't flame b/c I got it under control Yeah, all you get in the box is the springs, instructions, and stickers!
Old Mar 4, 2003
VNlilMAN's Avatar
The Standard One
ya it doesnt come with spring isolators.. stock springs should have come with some i think.. mine didnt..
Old Mar 5, 2003
SedanBoy's Avatar
what can i use in replacement?.... would silicone hose be ok?..... or can i actually buy spring isolators form the dealer?..... do you know the part number?..... and can i buy bump stops from the dealer too?...... any part numbers for those?.... thanks!
Old Mar 6, 2003
VNlilMAN's Avatar
The Standard One
front bumpstop - part number 465466 14.69 each.
rear bumpstop - 369111 6.92 each
the spring isolators i'm not sure if you can get from the dealer but i know there was a tsb for noisy springs and the dealers use the isolators to solve the problem.. so ya maybe they would.. i know energy suspension makes them as well. a silicone hose should work, might be a little thick tho. basically all your trying to do is put something in between the bottom of the spring and the bottom perch so that they dont rub/hit against each other
rob2905
Sep 8, 2015 01:26 AM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
kevinjdm
Sep 5, 2015 12:58 AM
cukaracha
Aug 29, 2015 05:27 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
