Ground Control Creeking question...
Old Feb 28, 2003
HRocket2k2's Avatar
HRocket2k2 is an unknown quantity at this point
Does anyone else have/ or had this problem with their ground controls.. my rear is creeking alot, is that normal? will it go away? Also is there away i can make it stop, the only way i can make it stop is by turning up the volume **** on my stereo.. please help.. i will be greatful for your responses..
Old Feb 28, 2003
Vinh's Avatar
its normal with ground control....
don't sweat it....it probably won't go away
but members on this site said they greased it....good luck
Old Feb 28, 2003
HRocket2k2's Avatar
man i am gonna shoot myself or something cause of all the creeking.. will dynomatting the trunk help? lol i will try anything..
Old Feb 28, 2003
Logan3024's Avatar
Quote
[hr]Originally posted by: Vinh
but members on this site said they greased it....good luck[hr]
When i tried greasing mine, I ended up gettin 50,000 little pebbles in the threads, it was so bad i could not even ajust the car! So what i ended up doing is using almost a whole can of degreaser removing the grease, and went to HOME DEPOT to get a 5mm thick plastic washers (used for for plumbing), which measured 3 1/2"(round) and a hole in the middle that measured 2", so it fit PERFECTLY . I put it at the top, where the top of the spring and the body of the car make contact , now it prevents metal to metal contact. This solved all my problems! no more squeeks!
I had this problem in the front not the back though.
RSJ
Jul 23, 2015 11:29 PM
califcamper
Jul 21, 2015 10:34 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
