Koni adjustable point broke what to do?
Old Feb 27, 2003
MattC1's Avatar
MattC1 is an unknown quantity at this point
The adjustable point broke on one of my rear shocks should I contact koni? what a pos all I did was try and tighten it and it broke off.. It's stuck on really hard now. Will they cover this? I bought this used off someone on this site
Old Feb 27, 2003
KeNsHiN's Avatar
LEVA
used, huh[IMG]i/expressions/face-icon-small-confused.gif[/IMG] maybe if you don't tell them that and if you have the receipt
Old Feb 28, 2003
Intruder's Avatar
Intruder is an unknown quantity at this point
Koni's warranty only covers the ORIGINAL PURCHASER of the products. So unless you find a way to pull some strings you are out of luck....
Old Feb 28, 2003
VNlilMAN's Avatar
The Standard One
if anything, maybe try to weld it on?
or just buy a rear koni, return the broken one so that now you have two new ones. sell the other one..
Old Feb 28, 2003
MattC1's Avatar
When the point broke off it was set to really FIRM so I had to set the other one to firm also, I was just wondering if I leave them both at firm. Will they blow easy? might just ride with them untill the rears blow out then replace them
Old Feb 28, 2003
VNlilMAN's Avatar
The Standard One
oh the damper adjusting thing.. i thought you were talking about the height clip thing, my badd...
can you adjust it with pliers or vice grip?
Old Feb 28, 2003
MattC1's Avatar
I'm talking about the little metal piece that comes out of the shock that little thing broke off and fell in between my rear seats so I can't weild it back on no more.. I also can't adjust it cause I can't get the adjusting **** on it becasue it broke off even with the shock.
Is there another way of adjusting the damn thing? ANd if I leave it at the hardest setting will the shocks blow faster? the roads here are s**t and I have winter
hans.pcguy
Jul 12, 2015 12:19 PM
Shakzhussain
May 17, 2015 12:03 PM
cukaracha
May 16, 2015 07:36 PM
Dakker
Jan 6, 2002 04:32 PM
