to trim or not to trim bumpstops.
Old Feb 17, 2003
Nuts's Avatar
Nuts is an unknown quantity at this point
i have the neuspeed sport springs and it came with a paper that said trim rear bumpstops 1.25". I know its not a very good thing to mess with all that but anyone with these springs trimmed them or not? i don't think i'm gonna trim them.
Old Feb 17, 2003
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
i have neuspeed race springs, i trimmed my bumpstops, but blew one stock rear strut about 1 month after install, then i put koni's on and no problems since.
Old Feb 18, 2003
EnProceso's Avatar
my goldline springs said to trim the bump stop too, like an inch or so. i read somewhere in the suspension forum that the ride is better, smoother, less bouncy when you trim the bump stop, something about since your using shorter springs you wont bonce off them. i think you should trim them the recommened length, they recommend it for a reason!
Old Feb 18, 2003
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
Cut them in half.
They need to be shortened as to allow for more suspension travel, which is necessary due to the decreases usable area created by lowering the stock gap.
duh.
Old Feb 18, 2003
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
My friend did it in his 99 SI with H&R race and the car ride like crap [IMG]i/expressions/face-icon-small-puke.gif[/IMG] to much bounce.. I say just get coil overs
Old Feb 18, 2003
HondaGuru's Avatar
It has NOTHING to do with bump stops. Unless you are bottoming out the entire compression area of your suspension they arent even being used.
His ride is harsh because
A) He picked "race" springs
and
B) This was done on stock shocks.
Then again you could just be a p***y and are not used to a stiff suspension. Thats for you to determine.
Old Feb 18, 2003
VNlilMAN's Avatar
The Standard One
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG] to joe
cutting the bumpstops only increases suspension travel. it doesnt give you a better, smoother ride, it just simply prevents you from bottoming out on them. say with stock springs, you have a 3" suspension travel, you lower your car 2.5" and now you only have .5" suspension travel which isnt much. you hit a dip and what happens, your shocks get compressed all the way down to the bumpstop and you bottom out on them, you cut them 1"(or whatever it tells you to cut them) so that you have 1" more shock travel. so instead of only have .5" you now have 1.5".
tuvok
Sep 25, 2015 03:13 PM
rayman009
Sep 12, 2015 08:30 PM
h4ldol
Sep 10, 2015 12:25 PM
honda.lioness
Aug 21, 2015 02:36 PM
Amulon
Aug 18, 2015 11:03 AM
