front-end alignment
Old Feb 10, 2003
mongo's Avatar
mongo is an unknown quantity at this point
front-end alignment
i am about to install some neuspeed sport springs. Does anybody know if i am going to have to get my front-end aligned?
Old Feb 10, 2003
4bangin's Avatar
yes, i recomend it. i have goldline which is around the same drop and i had them install front and rear camber kits. i drove for about 2 days and it wasnt to bad, then i got the front and rear aligned and the camber re-adjusted and it drove 100 x better and handled much better as well.
Old Feb 10, 2003
666's Avatar
666
666 is an unknown quantity at this point
Your tires will wear more evenly with an alignment and also be much more safe.
Old Feb 10, 2003
djmota's Avatar
camber kits and 4 wheel alignment . fork over a little cash now and save yourself from getting new tires alot sooner than you should.
Old Feb 10, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
about how uch does it cost to install camber kits and the actual camber kit?
Old Feb 10, 2003
scatman's Avatar
Still in the game...
you def should, i put on eibach sportlines and all my wheels ended up angling out
jdawgzcivic
17
Feb 1, 2020 04:16 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
