Anyone ever lower an Accord
My friend has a 98 Accord and he asked if I would help him lower since he knew I lowered my civic. Anyway is it any different form our civic's,
are there any DIY's available? Any help would be greatly appreciated.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
My buddie had a 98 oor 99 I dont remember, it was a coupe EX and we lowered his.
Its almost the same as civics. It'll take about 4-5 hours have good jacks in handy and jack stands. Take your time and invest in compressors.
My bro has a 2000 accord ex v6 coupe. He lowered his car w/ the Apex-I full coilover system. Its a little different for the accord because they all have double wishbone suspension and the front tower perch doesn't need to be cut for the coilovers. I hope this helps. BTW Apex- I is only a height adjustable system the dampening is single setting.
The Standard One
ya our suspension is different so its not exactly the same.. it should be similar tho..
try going to like clubaccord.com or v6accord.com.. i think those were the sites name, i forget..
My girl has a 2001 accord sedan. They have the same susupension setup. We put in Weapon-R circuit pro coilovers. They ride soft with the stock shocks. Its easier to lower than our cars. Double wishbone in the front and 5 control arms in the rear. Just remember to remove the shock assembly then work on the car. You can pop the top nut off if you want. Just make sure you will be able find it afterwards. Its not that hard, it all depends on the the spring compressor you use.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
beanhead
Sep 24, 2015 12:04 PM
