strut tower bar
Old Jan 8, 2003
RyzRocket02's Avatar
RyzRocket02 is an unknown quantity at this point
strut tower bar
I just bought a generic strut tower bar from Allman. He mentioned that I had to move something to get it installed, but I can't remember what it was. Anyone know what it was and how to do it? Thanks!
Old Jan 9, 2003
stlblues13's Avatar
stlblues13 is an unknown quantity at this point
I think you are talking about the clutch master(?)/slave(?) cylinder that has to be moved. I have a 5-speed and had to move it when I installed my Neuspeed strut bar. It is not a big deal, just hard to reach to bolt it back up. There is a nut on a silver bracket right below the cylinder that bolts the bracket to the strut tower. There is a big hole in the strut tower maybe an inch below/diagonal of that. The trick is to unbolt the bracket, slide it down there while being careful not to tip it, and then using a longer bolt, bolt it to that bigger whole. Like I said, it is not hard to do, it is just hard to reach in the fender well to hold the bolt. No biggie. Sorry, no pics, but it should be easy to find.
Old Jan 9, 2003
Rider's Avatar
Rider is an unknown quantity at this point
Yeah just to confirm what stlblues13 said..I done it on a friend ride....it is not that hard....just take the time to do it...it's not a big deal...!!!
Eric
Old Jan 9, 2003
Thanks man! Do you know what size (diameter and length) I should get? Any special tools I need? Thanks!
Old Jan 10, 2003
stlblues13's Avatar
[IMG]i/expressions/face-icon-small-frown.gif[/IMG] I cannot remember for sure. If I recall correctly the bolt was not all that long and I think it was a 10mm head and nut. I think the thing was it had a big (inch diameter??) flat washer on it. I did not buy it separate, it came wiht the Neuspeed bar. If you look below that bracket I mentioned you should be able to guesstimate what you need. Try looking in from the driver's side wheel well too to see where the other end goes.
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
