LX to EX front sway bar conversion?
If i just buy the front sway bar off of an EX will it just bolt on or is their modifications that has to be done, so i can fit an HP header and High Flow cat by the sway bar? Also how much will one cost?
DIY King
Actually...
Here's the LX's front sway bar:
The EX's does look a little different. On Majestic Honda's website it doesn't show it, but the EX's front sway bar has a much bigger center hump for the catalytic converter to fit through. The LX's front sway bar is flatter (as shown in the picture). I just bought the Progress front sway bar for the EX and as you can see...
The shape is rather different. The only way to be 100% positive if it's different is to compare the front sway bar from the LX to a front sway bar from an EX. The part numbers on Majestic Honda's website are different though, so that say something...
Anyway, yes. It'll fit. An EX's front sway bar costs $59.83 + shipping from Majestic Honda (www.hondaautomotiveparts.com).
yeah that would be me....i agree with grey the bar is different in that it has a huge bump for clearing the cat...you'll be able to use your lx/dx endlinks, bushings and bushing holders...the bars just swap out
www.ImportFactor.Com
I did the conversion to my car also but here's what I found out in the process:
I dont know if its the sedan vs. the coupe or the auto vs. the manual because I have a auto sedan, and for some reason I didnt even need to swap out the bar...it was just fine.... Anyone have any ideas?
DIY King
Quote
[hr]Originally posted by: WhosYoDadday85
I dont know if its the sedan vs. the coupe or the auto vs. the manual because I have a auto sedan, and for some reason I didnt even need to swap out the bar...it was just fine.... Anyone have any ideas?[hr]
Quote
[hr]Originally posted by: MugenRacerX
1 of my customers is doing what you are talking about right now... ill try to see if he'll contact you maybe,.... to help you with any tips.[hr]
ok i got the bar in today and will probably install it tomorrow... it doesnt look that different ... maybe like an inch. but i think i remember that the cat only needs about an inch more clearance to fit, so hopefully it will go smooth with no rattles when im done
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
