Ground Control Adapters???
Old Dec 30, 2002
Vinh's Avatar
i just bought the Ground Control Coilovers at tornactive with no adapters.
am i in big trouble because i should have ordered the koni adapters with it?
i plan on installing the ground control coilovers at 2" drop with stock shocks and run on it
for maybe about three months until i have enough for the koni yellows
wut is this adapter thing anyways?
Old Dec 30, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
The only adaptors you need are the front upper bearing adaptor (mfr'd by Ground Control, should have come with the kit) and the rear upper urethane perch (mfr'd by Ground Control, should have come with the kit).
You do not need an adaptor to fit the rear threaded sleeve over the rear shock but you will want to use the urethane inner sleeve that fits between the shock body and threaded sleeve for a nice tight fit.
The adaptor that you are referring to (I'm assuming that Tornactive told you that you need it or Koni did or someone on this site), is not necessary. I bought it but it doesn't really help. Also, it's only for use with Koni shocks.
TJ
Old Dec 30, 2002
Vinh's Avatar
hey dude,
thanx a lot man ...that helps....wut a relief
thanx again for your response
RSJ
Jul 23, 2015 11:29 PM
califcamper
Jul 21, 2015 10:34 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
