Problem with the progress tie/ sway bar
Old Dec 18, 2002
HondaLuver's Avatar
Its a celebration bitches!
well i heard, that there are problems with the progress sway/ tie bar on cars with a custom exaust, but i was thinking that if my car already has an exaust with custom piping and i already have a stock sway bar(ex), there shouldn't be anyproblem since it is replacing the stock/ oem bar...
Old Dec 18, 2002
CapYoda's Avatar
Escaped Convict
er...
no.
people have problem because the progress is 22mm... quite a bit bigger than the stock 12/13mm... and it gets in the way of aftermarket exhaust pippings...
not sure if it'll get in the way of urs... but yeah.
Old Dec 18, 2002
robbclark1's Avatar
Retired suspension supermod.
Even the 19mm RSX-S one sometimes hits my DC sports exhaust. U might have the get the piping bent a little to fix it.
Old Dec 18, 2002
Grey's Avatar
DIY King
I hear that the HKS exhaust fits perfectly with the Progress Group's rear anti-roll bar; there's supposedly an inch of clearance. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Anyway, I'm getting that anti-roll bar first. Then I'll make my own exhaust system and make sure to route the piping in such a way so as to allow for enough clearance with suspension travel and what not...
Old Dec 18, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
Yep,
I have the HKS Hiper axle-back exhaust with the Progress Sway/Tie bar combo. Everything clears perfectly with about 1" all around.
Thanks Grey for mentioning this...
Terry
Old Dec 18, 2002
djmota's Avatar
the thickness is only a tiny bit of the problem. the way the bar is shaped is the big problem. it is bent different than stock.
Old Dec 18, 2002
djmota's Avatar
hey robbclark1 did you have to put a dent in your exhaust to get the rsx bar to fit ? Please let me know as I will probably be giving that one a try.
Old Dec 18, 2002
Grey's Avatar
DIY King
Don't do that, I would bend the hangers so that the whole exhaust sits higher. That is if you have the clearance with the bumper. You can bend a couple of those to get it to work though. At least it seems like you can... [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 18, 2002
badcivic2002's Avatar
badcivic2002 is an unknown quantity at this point
hey 3rdcivic:
how do you like the hks hiper?
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Jodster
Dec 15, 2001 07:49 PM
jessepimpride
Nov 13, 2001 05:59 PM
