Progress rear sway bar problem
Old Dec 12, 2002
djmota's Avatar
Ok I got my sway bar the other day. today i decide to install it. Unfortunatley the F**king thing does not fit with my DC TCS muffler. Now I'm not bagging on the sway bar or if your **** the anti sway bar It is an excellent part and I wanted to put it on very bad. But now I've got to sell it because it is not compatible with my TCS system . No.... its not upside down. I checked multiple times.
So now I go the way of the RSX deal. But my question is will it have fit problems.? Does anyone have this set up with TCS?
So be warned it does not fit with DC sports TCS muffler system.
Old Dec 12, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
EASY SOLUTION:
Sell the stupid DC Sports TCS and buy the HKS Hiper axle-back exhaust. This exhaust and the Progress sway-bar fit very well together (leaves at least 1" of clearance in all potential contact areas).
The TCS is a waste of money anyway.
Old Dec 13, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
does it hit the actual muffler or just the exhaust pipe? mine has a problem hitting the pipe, just barely made a knocking sound but it was annoying and this was because I lowered my exhaust 1" in the back due to my body kit (didn't want to melt it!) Anyways what I did was tied some coat hanger around the exhaust and pulled it to the side a little bit and tied it to the toe hook in the back. IT doesnt vibrate any more. Anyays you might want to try that unless there is no way it will work...
Old Dec 13, 2002
djmota's Avatar
it hits the pipe going into the muffler its just not going to work. moving it to the side wont creat enough clearence and would put the muffler tip into my kit. and once the car gets put on the floor it will move even closer to the pipe. Thanks for the idea.
and 3rdcivic. I like my exhaust.... so [IMG]i/expressions/face-icon-small-tongue.gif[/IMG] I plan on keeping it.
the sway bar will be for sale soon in the marketplace.
Old Dec 13, 2002
VNlilMAN's Avatar
The Standard One
i say bang the **** out of the pipe till it gives enough clearance for the bar
how much would you see the sway+tie bar for?
Old Dec 15, 2002
mrdan4548's Avatar
mrdan4548 is an unknown quantity at this point
hey my 22mm progress sway bar does that on a stock exhaust. Since i got a stock exhaust my friend recommended just like vnlilman said "bang the pipe" for clearance or just install it and let the bar do it for you.
btw does anyone else have this prob?
Old Dec 15, 2002
taino's Avatar
taino is an unknown quantity at this point
Sorry that this is happened to you. but don't feel bad because the same s__t!!!! is happening to me and more. a few minutes after i wrote about this i read your add. and i am having the same problem plus i broke one of the end links ($65) in less that 2 hours. on top of that the damm swaybar hits the bar that goes underneath from the body to the the drum.
Old Dec 15, 2002
sumama's Avatar
sumama is an unknown quantity at this point
just get the rsx sway bar. no problems, no tie bar needed, fits perfect, and works great.
EDIT: and its pretty damn cheap compared to Progress. Got mine for less than $80 with bushings at the dealer.
Old Dec 16, 2002
djmota's Avatar
ya the thought of banging the **** out of my pipe came across my mind but I would almost have to bang it half way thru...kinda beats the idea of hiflow exhaust.
The rsx bar will definitly be the one that i will get.
VNlilMAN
I am thinking 185.00 + shipping for the bar all parts hardware stickers ect. I work in Corona Ca If someone wants to pick it up ..I would rather do a face to face deal than ship. Also next week I will be in the LA area for the holidays. I figure I got it for 191 plus tax So a lilbit of a discount for my misfourtune.
Old Dec 17, 2002
IDQcivic's Avatar
If the progress bar didn't fit which is 22mm then why do you think the RSX bar will fit which is 19mm, whats only 3mm difference, and 3mm is pretty tiny. You are talking that you'd have to bang half way through your exhaust or something to make it fit??? Well unless the RSX bar is shaped differently, you'll probably have a problem with the RSX bar too, just a thought...
Old Dec 17, 2002
djmota's Avatar
Exactly right!!!!!!!!!! the reason the Progress one does not fit is not because of the thickness its because their design/shape is different than stock. Why they did this I don't know ...maybe it adds to its rigidity, but god how friggen stiff do you want it its already 22mm. I'm hoping/ betting that the RSX bar will have the same if not close to the same shape as my civic one and clear my exhaust.
Old Dec 18, 2002
NytRyder2k2's Avatar
Bay Area
i just got my progress rear sway installed and i had no problem clearing my exhaust. not even coming close...i have magnaflow 2.25 piping
Progress Rear Sway/Tie Bar=
Old Dec 19, 2002
robbclark1's Avatar
Retired suspension supermod.
Even the RSX-S sway bar hits my TCS sometimes. u can what was said or you take the exhaust to a muffler shop to bend the pipe slightly to clear to bar.
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Firefly
Nov 28, 2001 06:13 PM
CapYoda
Nov 11, 2001 05:17 PM
